Tire Size and Stock BE Wheels
Jim_Gruber
What is the widest tire I can use on stock BE Rims on a Bugeye with stock springs. 155/80/r13 is typically used. Can I go to a 165/70/r13 or a 175/70/r13 on that rim? Thinking I need to get a 5" rim to go to a wider wheel. A BE Rim is either 4 or 4.5 " wide? Thanks.
Going from memory... a bugeye rim is 4" wide.
Don't buy tires yet. If your project stalls the tires will go bad before you finish it.
Jim_Gruber
Jim_Gruber
Not planning on buying yet. Trevor. I'm slow getting this back together but not that slow. Trying to put a plan in place for buying at the right time. So I know a 155/80/r13 fits. How about a 165/70/r13 on stock rims? I've been able to find 155/80, 165/70. and 175/70/13 out there.
drooartz
Don't know if you can go wider, but I had a set of 155/80/r13 on the Tunebug and they worked really well. Will do similar with Penny. The car was plenty fun to drive and handled fine, even with the hotter motor I had.
Jim_Gruber
Jim_Gruber
Thanks Drew. 155/80worked well on Bugsy I my '68 Sprite.
Didn't mean to imply you are slow, but buying your tires right before the first test drive means you'll get more use of them.
nomad
My BE came with 165/80 tires on it. They were old Michelin's with nice stiff sidewall's. I replaced them with some new Firestones and couldn't stand the car without around 35psi in the tires because the side wall's of the modern tire's are as thick and as flexible as inner tubes used to be!. Can't get the 165/80's any more though they seem to fill the wheel well just right so now am running 155/80's. I would sure consider 14" wheels and low profile tires since the selection of 13" is getting so thin. Of course you would lose your BE rim's.
Kurt.
Jim_Gruber
Jim_Gruber
Kurt,
trying to to save for Hap's Black Friday sale!
aeronca65t
I have these ~Faulken 175/70-13~ tires on my street Midget.
The car has 3.5 X 13" Austin rims (identical to a Bugeye but from an A35 sedan). It drives nice and with 28 psi, I see no signs of the tire rolling off the rim.
$232 for set of four with free shipping.
59diamond
I might as well get in on this discussion because I am awash in tires and rims. I have a set of Firestone 520/13 -2 inch whitewalls on rims and balanced with 500 miles on them that I bought in August 2013. I took them off as part of the sale of my Bugeye to lower the price for the buyer. They are sitting in my garage waiting to be put on someones car.
I also have a set of black walls size 155/80R13 on rims an balanced with about 200 miles on them that came as an extra set of tires with the new Bugeye I bought. I also have one really nice set of AH HUb Caps that can go with either set of tires. Anyone interested send me a PM. I need to make room in the garage.
Rut
I've seen the pictures of both sets and they look like new! Very much a bargain IMHO and if I wasn't on the other side of the country a set would be mine.
Rut
Jim_Gruber
Jim_Gruber
Thanks Nial now whether you could get a tire store to mount would be the question.
Rut
Down here its $20 per tire to mount and balance which seems steep to me.
Rut
59diamond
Well where I am at it cost me $25 each to mount and balance the White Walls. So along with the purchase of about $600 for the tires themselves plus the $ 100 for the rims you can see how things can mount up. Thats why I think they are a steal at $450.00 plus whatever shipping costs. I am a retired CPA and I know all about "SUNK COSTS"
nomad
The tire business is interesting! A few years ago I could buy tires on line and have them mounted for next to nothing. It appears that the guys that do this came to there sense's and figured out that if they couldn't make money off selling the tires they would make it off of mounting them! Can't blame them i guess. $20 a tire here as well....I can mount them but can't trust my harbor freight bubble balancer.
Kurt.
drooartz
Sunk Costs, otherwise known as the alternate title of any Spridget restoration. At least any one I've done. :grin:
aeronca65t
I mount my tires with two tire irons. I have a hand operated bead breaker to pop them loose.
I made a 4X4" adapter for my bubble balancer so I'm balancing them on the studs and not on the punched hole in the middle of the stock steel wheels.
I usually charge myself one beer per tire. :friendly_wink:
59diamond
I just own and drive cars. How I wound up with all these tires is beyond me. I bought my present Bugeye so I could take my wife to our 50th wedding anniversary in the car that is the exact replica of the one I sold in 1963 to buy her an engagement ring. I just want one car with 4 tires and a spare. So make me some low ball offers for these tires and you might get to own them.
The_architect
Jim, mine came with rotted 175/70/R13s and not knowing any better I replaced with the same size. I'm quite happy with them, but I've nothing to compare them to. Charile
Morris Stock tire size Spridgets 11
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
M TR5/TR250 Compatible Modern Tire Size Triumph 5
F TR2/3/3A Spare Tire Size Triumph 11
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
D Series II E-Type tire size Jaguar 9
H BJ8 tire size Austin Healey 14
T TR5/TR250 TR-250 Tire Size Triumph 6
NutmegCT Tire size substitution Restoration & Tools 4
B experience with tire size changes? Other British Cars 2
B TR2/3/3A Tire Size Triumph 14
britlover proper tire size to replace 5.90-15? Austin Healey 16
S General TR Tire Size Triumph 18
B T-Series MG TD metric tire size MG 5
B New VTO wheels ?? Tire Size for TR3 Racing 7
B VTO Wheels/Tire Size Triumph 13
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
R TR2/3/3A TR3 Tire brands and size Triumph 5
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
tmc Tire size for the spare Triumph 10
V Tire size consensus Triumph 4
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
J Tire size Spridgets 8
L What size tire will fit... Austin Healey 17
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
toysrrus RE: Tire Size Suggestions Wanted: Triumph 5
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
MTribe TR6 TR6 tire size photos? Triumph 30
tomshobby tire size? Spridgets 11
D Tire size for 73 midget Spridgets 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
6 Tire size conversion Triumph 0
htchevyii MGB need tire size recommendations for 77 MGB MG 6
E BE Tire Size Spridgets 20
L Street Tire size for 60 spoke wheels Austin Healey 15
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I Bugeye tire size Spridgets 3
longbridgehealey Tire size Spridgets 12
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
R Group 44 tire size ? Triumph 0
JPSmit Tire Size website Spridgets 3
Dave Richards Yet Another Tire Size Question Austin Healey 11
TexasSprite What tire and size for Minilite wheels? Spridgets 1
