TR2/3/3A TR3A Spare Tire Well & Tire Size
TEXAS_TR3A
Member
Did a search and came up with little so here goes....Got the 3A converted from steel wheels and hubcaps to 60 spoke wires last night, but discovered something I didn't expect to find. The spare, also 60 spoke and 165/15, didn't want to fit into the spare tire well. What size is normally recommended? I was under the impression (wrongly it seems) that the 165/15 was very close to what the OEM size tire was on this car(ancient 5.9x15 BF Goodrich I had as a spare). At 35psi it was not about to go more than 75%.....
Plan B? Deflate and carry a pump of some type in the trunk?
martx-5
The pre 60K cars have a spare tire well slightly smaller then the post 60k cars by about 3/8". The later cars will accept a 165 -15 wire wheel and tire, as that is what's in my car. It's a little snug, by I can pull it out easy enough. The earlier cars well was sized for a 155 - 15 tire, but your signature shows a '60 TR3A, which would be a post 60k car. Also, IIRC, the wire wheels will only go in one way, as in they won't go in if flipped the wrong way. I forget which way is which. I'd have to look in my car, but I believe that the part that goes down is where the knock-offs seat up against.
T
TEXAS_TR3A
Member
martx-5 said:
The pre 60K cars have a spare tire well slightly smaller then the post 60k cars by about 3/8". The later cars will accept a 165 -15 wire wheel and tire, as that is what's in my car. It's a little snug, by I can pull it out easy enough. The earlier cars well was sized for a 155 - 15 tire, so if you have a pre 60k car, that might be your problem.
Appreciate your thoughts above. What's so strange about it not fitting is that I've got a post 60K number car.
TR3driver
Great Pumpkin - R.I.P
One alternative is to use a "compact spare" type tire as a spare. Fits easily in even the smaller early spare tire well, and leaves extra room for other spares. I stuff a cheap blanket in to keep the tire from sliding around, which doubles as something to lay on if I have to do a "roadside tech session" or if my passenger's legs get too cold.
I got the tire & a wheel from the local junk yard for about $15. Thought the wheel might work, but it wouldn't clear the calipers so I mounted the tire on a standard TR3 wheel instead.
TR3driver
Might be because of the 60 spoke wheel. Are you putting it in hub-down as Art suggests?
RonR
Just about 3 hours ago I tried to install my new 165 x 15 Vredestein spare tire which is mounted on 4 inch wide steel wheel in the spare tire compartment of a 1960 TR 3a and it would not go all the way in at 30 psi. It's stuck, I was hot, I quit for the day.
T
TEXAS_TR3A
Member
Must be the 60 spoke issue because I tried hub down after first failed attempt with hub up. Think I am just going to reduce air pressure and carry a good pump in the trunk. Hate to have a new wheel and tire go to waste just sitting in the garage.
RonR
With the tire pressure at 15 psi, the 165 x 15 will slide in and out of the spare tire well with just a little difficulity. Now I have to find room for a pump.
I am going to consider the compact spare very seriously.
Ron
T
TEXAS_TR3A
Member
Thanks Ron. For the time being 15psi is what it will have to be for me! Let us know how the compact spare approach works for you. Sounds like it works well for TR3Driver. I have room in the boot right now for a pump, but that may not always be the case, so I bet I end up going the same route at some point.
Geo Hahn
RonR said:
With the tire pressure at 15 psi, the 165 x 15 will slide in and out of the spare tire well with just a little difficulity...
I slather a bit of baby powder on the tire to help it slide in and have a nylon strap looped around the tire and rim to have something to grab to pull it out. I also carry a 12V air pump to inflate to driving pressure.
6TTR3A
<span style="font-size: 12pt"><span style="color: #003300">I mentioned this on a earlier thread; I got a 48 spoke wheel which has a 4" width as opposed to the 60 spoke with a 4 1/2" width.
My 165/85-15 tire fits snug with full tire pressure.
I put a loop of clothesline facing out so I can get a good grip to pull it out.
Installing it hub down leaves plenty of room for spare tubes, high visibility vest, etc. I pull it out every two years to make sure all is in order, since I've not had a flat in 50K plus miles.
For those of you with steel wheels, Randall's idea is tops !!!
Frank </span></span>
wheelguy
You want to use a 48 spoke 15x4 wire wheel. The tire size is a 155/80/15 tire. Vredestein makes that size. This combo fits fine. Wheelguy
Geo Hahn
I suppose a basic decision you have to make is whether you prefer a spare that is strictly a spare (e.g. space-saver or 48-spoke wire) or a spare that is a serviceable road wheel that gets the best of the old set of tires each time you buy new (or even a new tire & enter the rotation). I do the latter.
TEXAS_TR3A said:
...Got the 3A converted from steel wheels and hubcaps to 60 spoke wires last night...
You don't say how you did this, but if you are using spacers (i.e. did not shorten the studs) then you have the option of using a steel wheel as a spare. This ia what I do. Would have a slightly different offset but is fine for temporary use. Since I have 165/15s the steel spare just carries a decent used but not out-dated tire of the same size.
Of course you need sockets or lug wrench for both the bevel lug nuts and the 7/8s steel's lug nuts and (real important) 4 of the big lug nuts. I also have a 12V impsct wrench when traveling alone as the nuts on the front wheel adaptor could be hard to loosen if there is no one to apply the brake.
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
mgbmedic TR2/3/3A TR3A Weatherstripping / Trunk - Spare Tire Cover Triumph 11
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
rlandrum TR2/3/3A TR3A Spare Tire Well Bondo-fest Triumph 5
T TR2/3/3A Kuhmo 165/80-15 tires will NOT fit in spare boot for post TS60000 TR3A. Triumph 23
NutmegCT TR2/3/3A TR3A spare wheel compartment picture Triumph 24
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
