TR2/3/3A TR3A Spare Tire Well Bondo-fest
rlandrum
The spare tire cover on the TR3A was covered in about 1/8-3/8 in. of bondo. It appears as though this might have been done by a previous owner to cover up the holes for the escutcheons. A later owner must have ground down the bondo to open up the holes again, probably out of curiosity.
We blasted off all the bondo, and the panel is perfect. Placing the panel on the car, I see that it's counter sunk about 1/4 inch, and doesn't sit flush with the rest of the car now that it's bondo free. What's the recommended fix to bring the two into alignment? Should we shim the latches or try to adjust the latch catches inside the well?
NickMorgan
:iagree:
Yes, I think when you put the rubber seal in place, you will find that it fits perfectly.
rlandrum
rlandrum
That's probably it then, since I don't have the rubber seal installed. I thought about that as I held it up there, but it still seemed deeper than I wanted.
I'll wait until the rubber is installed before doing anything.
I just thought it was weird that there was so much bondo on thing that it took the better part of half an hour to sand blast it all off.
Don Elliott
When you test the new rubber seal, you may find that it's too thick and now the cover door stands proud (too far out) and it isn't flush with the body panels. Or you can't compress the seal far enough in to turn the latches that hold the cover door tight. I had to carve my rubber seal all the way around to get a flush fit. The carving was not even. Some places, I had to remove a bit of the thickness of the seal while in other areas, I had to remove more. Then I used contact cement to secure the seal into the groove for the seal with the join at the bottom center.
It's been fine since I did that 18 years ago and I've driven my 1958 TR3A 98,000 miles since then with no further problems with this seal.
Oh yes ! I had to re-glue it in twice at the bottom where it started to come loose. But it's fine now.
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
mgbmedic TR2/3/3A TR3A Weatherstripping / Trunk - Spare Tire Cover Triumph 11
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
T TR2/3/3A Kuhmo 165/80-15 tires will NOT fit in spare boot for post TS60000 TR3A. Triumph 23
NutmegCT TR2/3/3A TR3A spare wheel compartment picture Triumph 24
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
