TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3
karls59tr
Bronze
I have 650x15" tires on stock rims now. Can I put these tires on 5.5 X15" rims or will they rub the inner fender at full lock? Would I be further ahead with 180 or 195 X 15" tires Are they a lower profile? Wonder what would be ideal for the alloys on a "3" ?
TR3driver
Great Pumpkin - R.I.P
There is more involved than just wheel width; the offset is important too. But since I can squeak by with 205/55 tires on 5.5" TR6 rims under my stock TR3 body, I don't think you're likely to have a problem with the width of 6.50's. I do question how old they are, though, unless you bought reproductions from Coker or similar.
Practically all modern tires are lower profile than the old bias-ply tires were. The profile is identified by the second number, which is (roughly) the sidewall height expressed as a percentage of the tread width. So, for example, a 185/65 tire will have a side height of 185 * .65 = 120mm.
185/65-15 tires are very slightly shorter than the stock bias ply tires, but the speedo error is only about 4%, or 2.5 mph @ 70 mph. A good choice, IMO, and a perfect fit for 5.5" rims. I actually tried some once, mounted on the original 4.5" rims, and they worked out well for me.
K
karls59tr
Bronze
Thanks Randall. I shoudn't have any probem finding 185/65X 15 tires I dont think but I havent checked yet. Do they fill the wheel well enough so there is not a lot of gap showing?
TR3driver
They should, although honestly I didn't pay much attention at the time. I mostly remember what seemed like a big improvement in cornering ability!
My 205/55s are deliberately much shorter than stock, and the look still doesn't bother me, although some probably don't like it:
If I recall correctly, this shot was taken with 195/50 on the front and 195/60 on the rear.
60TR3A
I have 195/65/15 tires on 5.5"-width alloys on my '61 TR3A and at full lock they do rub the inside of the wheel well. I've just ordered a set of 5.5" chrome 72-spoke wire wheels from a UK vendor and also ordered 1/4" spacers from Moss Motors which I hope will push the wheels just enough outboard that they won't rub the outer side of the wells and will stop the inside well-rubbing at full lock. If it only rubs at full lock - which is at very slow speeds, anyway - I can live with that.
TR3driver
Are your steering stops adjusted correctly?
60TR3A
I haven't a clue. I've had the car all of 3 weeks and my mechanic will be getting it all of next week to go over all the systems and correct what needs correcting and install some goodies I bought. I suspect my steering needs some attention as it is very stiff and may need new lube &/or the rack rebuilt. I'll mention the rubbing to him when I drop her off on Monday.
I've learned over the years that I am very handy - at writing checks and signing credit card slips - but not at things mechanical. The list of my foolish mistakes is endless. Even today I screwed up a simple thing as a badge: Had a lovely RAC replica badge I was going to install on the badge bar and overtightened the screw and popped off the little nut that's brazed onto the back of the badge. I'll see if I can buy some "liquid solder" as someone I know suggested; otherwise, it's toast.
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
M TR5/TR250 Compatible Modern Tire Size Triumph 5
F TR2/3/3A Spare Tire Size Triumph 11
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
D Series II E-Type tire size Jaguar 9
H BJ8 tire size Austin Healey 14
T TR5/TR250 TR-250 Tire Size Triumph 6
NutmegCT Tire size substitution Restoration & Tools 4
B experience with tire size changes? Other British Cars 2
B TR2/3/3A Tire Size Triumph 14
britlover proper tire size to replace 5.90-15? Austin Healey 16
S General TR Tire Size Triumph 18
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
B T-Series MG TD metric tire size MG 5
B New VTO wheels ?? Tire Size for TR3 Racing 7
B VTO Wheels/Tire Size Triumph 13
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
R TR2/3/3A TR3 Tire brands and size Triumph 5
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
tmc Tire size for the spare Triumph 10
V Tire size consensus Triumph 4
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
J Tire size Spridgets 8
L What size tire will fit... Austin Healey 17
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
toysrrus RE: Tire Size Suggestions Wanted: Triumph 5
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
MTribe TR6 TR6 tire size photos? Triumph 30
tomshobby tire size? Spridgets 11
D Tire size for 73 midget Spridgets 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
6 Tire size conversion Triumph 0
htchevyii MGB need tire size recommendations for 77 MGB MG 6
E BE Tire Size Spridgets 20
L Street Tire size for 60 spoke wheels Austin Healey 15
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I Bugeye tire size Spridgets 3
longbridgehealey Tire size Spridgets 12
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
Morris Stock tire size Spridgets 11
R Group 44 tire size ? Triumph 0
JPSmit Tire Size website Spridgets 3
Dave Richards Yet Another Tire Size Question Austin Healey 11
TexasSprite What tire and size for Minilite wheels? Spridgets 1
