"Sticking" the brake pedal
steveg
I also setup a stick to hold down my brake pedal for 24 hrs. Now it's higher and harder than it's been in the past. :cool:
Will report back later on whether it holds.
PS - thought it would be useful to have this as a separate thread.
Deleted member 22741
Can you please link to the previous thread? This sounds interesting..
BOBBYR
Hey Steve , I've been following your bleeding issues . It reminds me of a certain type of brake system I used to work on . Keep us up on your progress .
Good Luck ,
Bobby R
healeyneil Sticking back brake BJ8 Austin Healey 0
K TR2/3/3A Sticking front brakes? Triumph 9
F Choke sticking Austin Healey 22
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
T TR2/3/3A Sticking Clutch Triumph 6
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
T throttle sticking? Austin Healey 4
T TR4/4A Overdrive piston is sticking Triumph 9
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
B Sticking Starter Pinion Austin Healey 6
M Sticking speedometer needle Triumph 2
J Oilcan spot on fender [IE: not flat, sticking out Triumph 2
J STICKING THROTTLE PLATES Jaguar 7
TR4nut H6 carbs -jets sticking Triumph 15
M Front brakes are sticking Spridgets 33
Kleykamp TR2/3/3A sticking clutch ??? TR3 Triumph 5
M Sticking M/C piston Triumph 7
Got_All_4 TR2/3/3A SU pistons sticking in TR3 Triumph 11
T TR2/3/3A TR3 Sticking Brakes - How come and what to do? Triumph 5
bcbennett TR6 Sticking TR6 throttle Triumph 28
TimK sticking rear brakes Austin Healey 8
R sticking speedometer Triumph 1
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
mountainman SU Choke sticking! Help Triumph 6
doughairfield Jet Assembly sticking Triumph 6
jtownhealey61 AH 3000 Overdrive - sticking engaged Austin Healey 4
R 1275 timing/ carb pistion sticking Spridgets 3
K Sticking Floats Triumph 12
M Bugeye clutch pedal sticking Spridgets 2
R TR2/3/3A TR3a- grose float valves sticking Triumph 6
B Sticking float valves Spridgets 12
Steve P. 1500 Midget; sticking choke Spridgets 6
NickMorgan Sticking horn push Triumph 8
A carburettor air valve sticking Triumph 3
George Zeck Choke is sticking ??? Spridgets 11
RickB Gas pedal sticking - maybe the cable? Spridgets 15
Morris Sticking Shock Spridgets 2
D Sticking Brakes Spridgets 22
X Throttle linkage sticking Spridgets 6
B Is my Thermostat Sticking? MG 9
R Clutch Sticking Problem Austin Healey 4
weewillie sticking butterfly Spridgets 8
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
R_Lyle Steering Rack sticking Triumph 4
T Sticking throttle - any ideas? Triumph 8
T Likely cause of throttle sticking open Triumph 5
B Carb Problem - Something's sticking Austin Healey 43
jollyroger Transmission sticking in 1.st Spridgets 3
D Sticking Bonnet Spridgets 4
Webb Sledge TR6 Sticking TR6 Clutch Triumph 15
