Spring height question
MGAdams
Maybe Tony knows?
I am lowering the front ride height of my 1962 MGB racer, and my measurement indicates a previous owner put in 1972 roadster springs that are 7.25" loaded height, 10.2" free height. My research finds a Pre-72 GT is only 6.6" loaded height, 9.1" free height. The on-line catalogues do not provide the actual height of the lowering springs they sell. The change would result in lowering of 2" in ride height.
Does anyone have a pre 72 GT spring they could measure to confirm my research, and/or know the actual height of the springs sold for the lowering kits?
Mike
tony barnhill
Great Pumpkin - R.I.P
I've got all kinds of used springs & the shortest I've found are 9-3/8" end-to-end...they came from under an early GT
Platinum
Mine are roadster, so no help. Can't quibble over a 0.20" discrepancy tho. /ubbthreads/images/graemlins/wink.gif
M
MGAdams
Jeff,
Right now I am racing to go racing .. so many things to finish up. The only VARAC event I plan to attend is the Festival at the end of June. Need to finish up the car first, get my license re-newed somewhere, and shake down the car before that long trip to Mosport. I live 6 hours away from the nearest track which is bad enough, but 2 days for me to get to Mosport.
Mike
Bugeye58
Well, not bad for a guess, eh?
I may make it up to Mosport for the June Festival. I've got a bunch of friends in Ontario that run VARAC.
Jeff
artmck
I just took springs out of my 74 roadster. They were 10" long unloaded. They had 8 coils if you start counting at the 'tail' and count the tail and the coil it is touching as a full coil.
My car was too high in front, and since I planned on replacing the springs anyway, I cut one coil off. I haven't driven it yet, but it is a bit lower. Don't think it would stiffen too much since those coils sit on each other anyway.
[ QUOTE ]
[/ QUOTE ]
Might not... But then again you'd be surprised at how much stiffer they can feel by cutting one coil off. I've seen guys cut 2 coils off of pickup trucks and the ride afterward felt like the suspension was fixed to the frame.
jlaird
Used cut off plymouth springs in my autocross sprite back in the 60s. Sure cleaned up the handleing, was completely flat at that point. shrug.
J TR2/3/3A TR3 coil spring height Triumph 4
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
58Custom Ride height issue, spring help Spridgets 8
rjc157 rear spring height Austin Healey 10
Jim_Gruber Spring height Spridgets 12
T MGA Height of stock front spring on MGA MG 2
N TR6 TR6 Front Spring Height?? Triumph 3
S Low Rear Spring Height Austin Healey 13
Darwin Front spring height? Triumph 3
John Loftus coil spring height Austin Healey 2
X spring ride height/ low profile tires/minilites MG 2
S TR2/3/3A tr3 valve spring compressor Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
