coil spring height
John Loftus
Does anyone know the factory specs on coil spring height for a BJ7 (probably the same as late BN7 through BJ8)? Can't find it in the workshop manual. Mine measure 10.5" with a height gage and I assume they are original because I can see the evidence of the color stripes that the factory used.
Cheers,
John
chapelfarm
Do you mean unladen height? This will depend entirely on the stiffness of the spring in question. I've just put what Denis Welch calls standard coils (their code suf123) from a BJ8 on my 100-6 on their recommendation - it rides beautifully and sits very well. The springs - unladen - are a good 1.5 inches shorter than my old 100-6 springs - the height really isn't the whole story!
Why not ask DW what they recommend for your application? New springs aren't too expensive and if yours are of fthe car anyway...
J TR2/3/3A TR3 coil spring height Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
D coil spring finish Austin Healey 5
KVH TR4/4A Front Coil Spring Spacers Triumph 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
RJS TR4/4A Coil Spring Clutch vs. Diaphragm Clutch Triumph 2
W Spitfire 1980 Spitfire Coil Spring Replacement Triumph 2
T TR2/3/3A Average life span of a TR3 Coil Spring? Triumph 5
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
H Coil Spring Compressor Triumph 10
G Choosing the correct front coil spring Spridgets 54
Baz Cracked coil spring! Spridgets 25
K Coil spring compessor again.... Triumph 8
K Safety issue:Coil spring compressors Triumph 9
T Recommendation on coil spring compressor Triumph 6
A A.H. MKII BT7 Coil Spring Free Length Austin Healey 5
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
S front/rear coil spring diamaters. Triumph 4
J Coil spring free length & correct brake servo? Austin Healey 2
nevets coil spring removal Austin Healey 7
61Alpine Coil Spring Removal Sunbeam (Rootes) 11
Jarhead Coil Spring Compressor Restoration & Tools 5
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
2 TR2/3/3A Coil issues Triumph 31
