Safety issue:Coil spring compressors
karls59tr
Bronze
I'm changing out the trunnions on my 3 and changing the top bushings to poly. There are some excellent pics at "TR Album:changing the front suspension" on the Net.The car is supported by two jack stands under the frame and a floor jack under the suspension to lower it when required. My question: a spring compressor is only required when your doing this work and the engine is out of the car and there is no weight there right?
Tinkerman
Karl, the factory shop manual. "Front Suspension" section page 8 and 9 talk about how to do it. When I did mine I had everything off so I had to use a spring compressor. If you don't have a factory shop manual you should get one at least get the CD thats available. As you may know they are a good source of info.
Good Luck, Tinkerman
NickMorgan
Karl,
I would always use a spring compressor, as if that jack slips you are in big trouble. A threaded rod with a metal plate on one end does a great job. If you use it in conjunction with a jack under the trunion, then the jack does the compressing or releasing and the threaded rod is there for safety.
Don Elliott
If your engine is not in the car the jack under the trunnion will just left the whole car and your spring will not compress. I have heard of TR owners putting about 400 lbs of patio tiles on the frame whhere the motor would be to do the job properly with the motor out.
The threaded rod is easy to make. See how Randall did his.
K
karls59tr
Bronze
So before you do anything to the front suspension you remove the shock and install the threaded rod? Wonder what grade of steel and size of rod he used...1/2"?
Don Elliott
The one I made is almost like Randall's. I made it about 20 years ago. Except where Randall has a round plate, which acts only a large washer and anything similar will do, I made and use an aluminium plate anout 1/2" thick with a center hole for the threaded rod and 4 smaller holes that locate on the studs at the bottom to help keep it central and to prevent any side slippage.
The rod is 1/2" 13 UNC threaded rod that you can buy in any Home Hardware, Ace or Home Depot. Very simple.
Opa
here's mine for a TR6. Plate mounts to the four shock mount studs. as Don says, 1/2" unc rod.
Alum. plate is 1/2 thick
vivdownunder
Karl,
The advice to use a centre spring compressor as per Don's photo is very sound. They're so cheap to make up. A jack alone is just too risky considering the huge latent energy in the spring.
When returning the spring, as the pan draws up towards the lower wishbone, the spring compressor allows you to juggle the assembly to get the pan onto the two inner bolts.
When fitting the upper inner poly bushes, you will most likely find the fulcrum pins need cleaning up with fine emery or the like. If you remove the upper inner fulcrum pin, it has to go back the same way around so the shocker rubbers clear it. Use the white lube that usually comes with the poly bush packs on the fulcrum pins, or the new bushes can squeak.
After the lower outer wishbone bushes are pressed into the arm, they need to be reamed to fit the trunnion pins, so you may need to outsource this job.
While the suspension is dismantled it is worthwhile to get the vertical links and axles crack tested, for peace of mind. Hairline cracks can develop, usually due to a whack or gutter hits, which can end up in failure with today's grippy tyres.
Best regards,
Viv.
TR3driver
Great Pumpkin - R.I.P
I used 3/4" threaded rod, probably only Grade 2. Wasn't quite 20 years ago, but it's rebuilt several TR front ends and shows no signs of wear.
Although I don't think the holes are essential, the piece of scrap I found for the lower plate (actually a generator pulley half from a VW Bug) was larger than the stud spacing, so I drilled holes for the 4 studs in it. But I believe a simple 1/4" aluminum plate that fit snugly between the studs would work fine (especially since there are commercially available models that are made that way). The piece I used was also pretty stout (and I still added another flat washer to back it up); I would not try to use a simple flat washer there (especially with the 1/2" rod).
Tinkerman
Made mine also. I would urge the use of a grade 8 all thread rod. No such a thing as being too safe!
Tinkerman
KVH TR4/4A TR4 Suspension Safety Issue? Triumph 4
mctriumph TR2/3/3A Forgotten safety item Triumph 3
F TR2/3/3A Bonnet safety hook Triumph 10
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Michael Oritt Fuel tank safety Austin Healey 18
Michael Oritt Safety-wiring knock-offs Austin Healey 24
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
D TR2/3/3A bonnet safety catch Triumph 4
P For Sale Five 6.50-13 Bias ply US Royal Safety 800 tires for sale Spridgets Classified 0
T For BJ7/8 Safety: add a quarter light mirror [or two] Austin Healey 6
maxwedge5281 over the shoulder safety belts Austin Healey 16
PAUL161 T-Series Door Safety Latches MG 9
GTP1960 TR2/3/3A Interpreting fuel pump safety switch wiring diagram Triumph 3
A Safety Devices Roll over Bar Austin Healey 2
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
healeyblue Boot lid safety cable Austin Healey 10
R Daimler SP250 Bonnet safety methods *PICS NEEDED* Other British Cars 1
tinman58 Safety First Triumph 3
aeronca65t Safety First! Other Cars 5
T simple addition for electrical safety Spridgets 7
I Bugeye gasline route/safety help please Spridgets 10
RandallRK Wire wheel spinner direction safety concerns Austin Healey 18
luke44 TR2/3/3A TR3 Hood Safety Latch Triumph 7
Tinkerman Shop Safety or Safe Room Under the Car Triumph 39
angelfj1 BRAKE CLEANER - PLEASE READ THIS SAFETY WARNING Restoration & Tools 13
kcbugeye1275 safety Spridgets 15
aeronca65t Race Safety-Nomex, etc Racing 2
D Garage Safety Triumph 48
W tire and wheel safety---pass it on! Restoration & Tools 0
G SHOP SAFETY Restoration & Tools 13
angelfj1 TR5/TR250 TR-250 Touring and Safety Kit Triumph 18
D Safety Fast Ford ??? MG 7
apbos Safety and S/U carb mess Spridgets 14
tosoutherncars Woo Hoo! Passed the safety Spridgets 2
philman Old Car Safety Items Triumph 15
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
MadRiver Octagonal safety knock-offs MG 7
TR4nut U.S. distributor for Safety Devices Roll bar? Triumph 4
SCguy TR6 TR6 Hub Safety Triumph 4
bighly Safety advice / tips sought Austin Healey 31
drooartz Passed safety inspection again Spridgets 7
Morris Oven Cleaner Safety Spridgets 9
G Thought I had a lifetime's supply of safety wire.. Triumph 2
G Safety wire gadget Triumph 21
Brosky LED Lights on Roll Bar for safety-more pics added Triumph 8
D Rollbar mounted safety harnesses Racing 4
D Safety Harnesses Spridgets 13
