Slave Cylinder bracket mounted where?
Tinkerman
Is the slave cylinder bracket mounted on the bell housing side or the clutch housing side of the engine? This is for my TR3, seems to me it should be on the bell housing side but just want to make sure.
Thanks, Tinkerman
Tinkerman
Tinkerman
Thanks Sail, just what I needed to know. Now if you could just tell me where my old one is................
Tinkerman
S TR2/3/3A tr3A mounting bracket slave cylinder Triumph 7
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
M General Tech TR2 Slave cylinder Triumph 0
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
AngliaGT 1275 - Just HOW Do I Bleed the Slave Cylinder? Spridgets 4
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
J How much movement in slave cylinder plunger . Austin Healey 2
S TR2/3/3A the slave cylinder goes Triumph 7
JPSmit 1500 slave cylinder question Spridgets 0
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
C TR2/3/3A Wrong slave cylinder Triumph 3
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
T Bleeding slave cylinder on BJ 8 Austin Healey 2
Lukens TR2/3/3A 7/8" Slave cylinder? TR3a Triumph 1
Boink Clutch Slave Cylinder dribble... Spridgets 20
T Slave Cylinder Rebuild Triumph 7
J New Healey Slave Cylinder? Austin Healey 1
G Slave Cylinder Support Rod Triumph 4
O TR2/3/3A TR3A Slave Cylinder Mounting? Triumph 4
Henson80MGB Trick to remove rubber hose to Slave Cylinder? MG 19
M Cutch Slave Cylinder what am I doing wrong [pics] Triumph 6
John_Mc Bench bleed slave cylinder? Triumph 4
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
T slave cylinder resleeve or buy new Austin Healey 2
Rut Slave cylinder suggestion Spridgets 6
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
AngliaGT Oh....Darn... - Slave Cylinder Triumph 6
Hairyone clutch slave cylinder Spridgets 14
B Can anyone identify this Datsun slave cylinder? Spridgets 4
I Tips for bleeding Bugeye slave cylinder? Spridgets 12
I Bugeye slave cylinder hook up Spridgets 1
