Servicing transmission and overdrive
drooartz
So it's time to do a drain and refill on the transmission and overdrive. I've got oil for the box (same VR1 20W50 racing I use in the engine -- easier to just use the same stuff) but wondering what else I need.
There's a filter(?) in the OD unit -- replace? Drain plug gaskets? Anything else? I'm putting in a Moss order and don't want to forget anything.
PAUL161
Drew, how's everything working now? Does the OD work ok? If these answers are yes, then it's a straight forward job. I'd just drain old out and refill. The MGB transmission is pretty bullet proof and if their working correctly, I don't fool with them. I'll probably get some flack on this, but if the transmission is quiet while shifting, I change oil in them when I see a darkening of the oil, which is rare. JMHO. PJ
drooartz
drooartz
Everything seems to be working fine. Transmission shifts fine, no issues there. OD takes a moment to engage, but disengages quickly. Leaks a bit, but that's not too surprising I guess. Not horrible, I just check the dipstick every now and then (it's usually fine).
I don't know if/when the OD was ever drained/cleaned/filter replaced (there is a filter, correct? Moss shows something). As the car is still relatively new to me (1 year) I'd like to have some piece of mind knowing that it's been taken care of.
Bob Claffie
If it ain't broke ------. Been there done that. Be aware that there are several plugs under the transmission that look like drain plugs. Some aren't. At least one of them contains a check ball and can be lost in an instant. Proceed carefully. Bob
bob67bgt
If you change the filter its behind the 2"x3" plate on the bottom of the trans. There are 6 small bolts holding it on. Be sure not to overtighten these and break them off. Dirt of grit can be a big problem with a overdrive. Be sure your funnel and the area around the fill plug are clean so nothing but oil goes in. Bob
drooartz
drooartz
Thanks guys. I'll check back in before I tackle this one and make sure I've identified the proper drain plugs and such.
bob67bgt
Only one drain plug on a later overdrives required to drain. Its the one closest to the engine. Its not close to the overdrive but will drain the overdrive since its at the lowest point on the trans. As I recall it takes a 11/16 or 3/4 inch wrench to remove it. Have a good scraper to get the screen/filter off under that 6 bolt cover. Do not remove the small cover with the wire coming out of it. That one has the little ball that can drop out and be lost forever. I use 30 wt non detergent oil in overdrives. Check Quantum Mechanics website for his advise on oils. Bob
drooartz
drooartz
Thanks, Bob.
PSJ
Hi Drew!
Don't want to inject confusion or delay - but I've messed up (in the past) by using incorrect oil in my OD gearbox. I am not familiar with VR1 20W50 racing oil; but the oil needs to be "normal" (non-synthetic) and non-detergent. After putting in oil that didn't meet these criteria, my OD stopped working - so I had to "rinse" with several changes of correct oil until everything worked perfectly again. I think the manual for my '72 calls out for straight 30W non-detergent. I had to do a little searching until I found that exact oil (it's now so archaic that it's no longer common in my neck of the woods). However, now everything works perfectly! I don't think you can go wrong using the manufacturer-specified weight and grade; though some may argue that you might be able to do better by using something else.
Good luck!
Phil
drooartz
drooartz
The VR1 is a non-detergent oil -- it's what I used in the Sprite box as well. Haven't done a full drain on this gearbox since I bought the car last year, just topped it off occasionally. Straight 30W is what Quantum Mechanics recommends, though the owner's manual says to use what you use in the engine (20W50 is one of the recommended weights).
I'll see what I can find before I do the service. There's no rush as it's working okay now.
L T-Series Gear box servicing cap. MG 5
S SU fuel pump servicing Austin Healey 4
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
S Servicing BJ8 drum brakes Austin Healey 3
M Proper servicing of overdrive Triumph 15
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
J Damper servicing MG 26
TR4 Servicing Trunions??? Triumph 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
