Sealant for freeze plugs
LarryK
Been using Permatex for 40+ yrs. without a failure.
KVH General Tech Head Gasket Sealant Triumph 4
Lin Oil sump sealant question Spridgets 0
B MGA Sealant for front plate? MG 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
T external sealant for oil leaks Spridgets 6
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
NutmegCT "Great Stuff" foam sealant Restoration & Tools 5
TomMull Hylomar and sealant choices Restoration & Tools 15
R Use sealant or not with new windscreen Austin Healey 2
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
CJD TR2/3/3A Steering Box Sealant Triumph 5
NutmegCT sealant? Restoration & Tools 3
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
M Head gasket use sealant or not Austin Healey 7
I TR6 Si sealant for TR6 heater box? Triumph 1
Stinger TR4/4A TR4A Black Tar Sealant Triumph 3
D Cork float sealant Jaguar 3
V Diff drain plug sealant? Spridgets 5
M TR2/3/3A TR3 Thermostat Housing Sealant Goop Triumph 3
T Valve cover gasket - sealant needed? Triumph 7
M Sealant Triumph 0
2wrench Sealant on headgasket or not? Triumph 16
davidk Head Gasket Sealant Triumph 4
T Gas tank sealant - Kreme or????? Triumph 4
B Upgrading valve cover - gasket sealant question Triumph 15
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
2wrench I'ts about the front engine seal and RTV sealant Triumph 13
N Correct sealant for windshield replacement Triumph 9
I sealant for sending unit Triumph 4
I TR6 TR6 windsheild aluminum cap sealant placement Triumph 1
G I've got Permatex Aviation Sealant on my Mouse. Triumph 13
N Fender[wing]sealant questions Triumph 17
H Sealant - Gas Tank Sending Unit Austin Healey 9
J Do you use sealant at the bottom of the cylinder? Triumph 7
6 Seam Sealant: Remove, Replace, Leave Intact? Spridgets 1
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Moose33 head gasket- use sealant or not? MG 7
mbrooks 100 Exhaust - torque settings, gasket sealant?? Austin Healey 3
T Difference between a WAX and a Paint Sealant? Restoration & Tools 0
T How 2 tell good wax/paint sealant from a bad one Restoration & Tools 26
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
SherpaPilot TR6 Questioning a Freeze Plug Triumph 3
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
F Brass freeze plugs BJ8 Austin Healey 4
tomshobby Have you checked your anti-freeze? Spridgets 1
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Boggsy64 MGB Freeze plug removal MG 7
M Healey 100-4 Freeze Plugs Austin Healey 1
