Difference between a WAX and a Paint Sealant?
tradertt
Hi, does anyone know the difference between these 2? Which is recommended to be used? And when should I use a wax and when should I then use a paint sealant.
Thank you in advance. Just trying to learn as much as possible.
M TR4/4A Difference between two Oval Air Filters Triumph 3
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
Got_All_4 TR6 Any difference between 69 & 70 camshafts Triumph 3
K TR4/4A Difference between 4A frames and TR6 frames? Triumph 6
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
M TR4/4A Is there a difference between the "Body" number and the Comission Number? Triumph 8
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
N 3" difference between front and rear track Spridgets 5
R difference between instal of 1500 radiator in 1275 Spridgets 3
T Difference between 1969-74 and later exhausts Triumph 7
Cookie Difference between 16acr and 18acr alternator Spridgets 1
B Difference between an HIF6 and HIF44? MG 5
F Difference between disk and wire rotors???? Spridgets 1
T Any difference between brake M/C rebuild kits? Spridgets 18
T TR6 TR6 fans - difference between years? Triumph 0
heliguy TR5/TR250 Gearbox difference between TR4A and TR250 Triumph 8
T MGA Difference between MGA front springs? MG 0
tony barnhill Interesting Difference Between 2 1985 Cars Jaguar 17
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
J coolant hoses - any difference between them? Triumph 5
J Is there a difference between fenders? Triumph 2
T Quality difference between Moss and VB carb kits Triumph 3
A Headgasket , difference between late and early ?? Triumph 2
frankenstang57 TR5/TR250 whats the difference between a 250 & a 4? Triumph 18
bighly The difference in specification between the models at a glance Austin Healey 2
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
drooartz MGB Difference in clutch master cylinders? MG 4
K BJ7 interior back panel difference Austin Healey 4
HealeyRick A 100 With a Difference Austin Healey 9
trrdster2000 GT6 Another little difference, big problem. Triumph 11
HealeyRick 100 With a Difference Austin Healey 6
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
T Weight difference beween steel and wire rims Triumph 11
K TR4/4A Difference in Clutch Shafts 4A? Triumph 4
M 3.0 iron weight difference Austin Healey 7
L For those who know the difference Lotus 5
bugedd Difference in 1275 heads? Spridgets 24
S ride difference oem vs poly bushings Triumph 4
H Steering box adjusted, what a difference Austin Healey 0
W Rear wheel cylinders...what's the difference Spridgets 1
Marvin Gruber Plug gap does make the difference Triumph 19
Jim_Gruber Vroom, Vroom-Oh what a difference in handling Spridgets 11
I Battery - does size make a difference? Spridgets 8
W Heater switch/cables - what's the difference? Spridgets 5
livinginthepast The difference a local shop can make vs. a chain.. Spridgets 9
