I think Dan Masters has an interesting take on Spark Plug gaps.
He writes:
"Bypassing the resistor is only one of the changes necessary to utilize the full advantage of the Sport coil, or any high output coil for that matter. Unless you also increase the spark plug gap, the plugs will continue to fire at the same coil secondary voltage as before, give or take a little, and will not give the hotter spark that you paid for. The voltage rise at the output of the coil secondary, although rapid, is not instantaneous. As the voltage rises from zero, as soon as it reaches the value high enough to jump the plug gap, it will. Since the plugs were firing at 20,000 volts with the old coil, that will fire at that voltage level regardless of the maximum voltage potential of the new coil. As soon as they fire, and the arc begins, the voltage drops to zero. By widening the gap, the voltage must rise to a higher value to jump the gap. Ideally, the plugs should be gapped to the widest setting that will still allow them to fire under all engine operating conditions. Usually, the coil manufacturer will give recommended gap setting, but these should be used as the starting point, and adjusted from there as experience dictates"
I know an old gearhead that adjust his plugs that way. He never uses a measuring tool, just his knife blade. He prys them open to the point where they fail to arc, then with a tap on the fender, closes them up a bit.
