Plug gap
EV2239
Sparks tend to pick the easiest place to occur, which ought to be the plug, but can be the rotor arm or the distributor cap if you open up the plug gap. I've not heard of it with Healeys, but it's certainly a problem with post war six cylinder R-R & B.
EV2239
FWIW Lucas had three different coils in the days of Healeys, one for Morris Minor type engines, a sportier one for Healeys and on with a red ceramic type top for D Type Jags etc. The Lucas gold coloured sports coil you can buy now does have a higher output than the original, but is a direct replacement. Sorry I've been too lazy to look up numbers.
Keoke
You Pertronix users, Are You running stock spark plug gap ?
NO!
Because the switching time of a Pertronix is much faster than the old points you are going to develop higher secondary voltage out of the coil. Consequently, you can now put more fire in the hole and improve on the combustion in the cylinder.
by opening up the plug gap to:
30-or- 35 Thou.
When you add a sport coil you can use a plug gap of 40 Thou.
NO!
30-or- 35 Thou.
From the Pertronix FAQ: "In most cases increasing the factory recommended gap by .005 improves the engine performance."
I sit corrected.
B
bdcvg
O.K. here's what I've found. 1. The Nissonger tach conversion does not like solid core wires, the RFI will make the needle flutter. 2. The Pertronix does not like solid core wires, they cause an intermittent misfire that will eventually cause the ingnition module to fail. I will now experiment with changing plug gap after tracing down My 2 issues.
Keoke
Well first off :
Solid core wire in just about any application is subject to failure from vibration and is not recommended.
Automobile wiring harnesses and spark plug wires should use the stranded wire type
Radio Frequency Interference [ RFI ] in ignition systems can be controlled by:
1 Shielding of the ignition system and it's multiple stranded wiring.
Healey used this approach early in life ,kits could be ordered.
2 resistance type plug wires such as string impregnated with carbon
3 Spark plugs of the resistance type.Such as Bosch WR7DP
4 There is a special type. spark plug wire that contains a built in inductor.
This usually consists a special winding installed around the main conductors .
5 There are spark plug connectors that contain suppression. I use Bosh works a treat
Michael Oritt
From the Pertronix page:
The Ignitor has no set specification in which the spark plugs should be gaped at. Every engine responds differently to spark plug setting. In most cases increasing the factory recommended gap by .005 improves the engine performance
In all of the race cars I have Pertronix ignitions in Lucas distributors. In the Healey I have a Mallory Unilite ignition. In all cases I use NGK B9ES plugs with .030 gap. YMMV.
There is no good reason to use solid core wires. They will cause ignition interference in your and nearby cars and I believe in some jurisdictions it may even be illegal to use them. I once changed a made-up distributor cap on my Courier and did not realize that the wires were solid core. The ignition signal turned the roll bar camera off-on continuously and did so even when the cam was powered from a different 12 VDC source.
B
bdcvg
The solid core wires were installed by My resto Guy Who focuses on stock stuff. The Pertronix is pretty good and I hope to have good enough weather to go back to .030 gap soon. I returned to .025 when the misfire appeared.
John_Progess
I was told that we should not be using solid core plug wires with a Pertronix because it could destroy the unit. I am using a Pertronix and I have solid core wires in my car and have not had a problem. Is this a true fact or garbage? Also what is the gap I should be using with a Pertronix? Thanks and have a good day!
John
BG 62AH
Any advice on plug gap for a Crane Cams XR700. I am currently staying with a stock gap, but have considered opening up .005.
Any suggestions appreciated.
John Turney
I've got 0.030 gap on my Champion RN9YC resistor plugs, and bumble bee wires with no problem.
steveg
John
This forum discusses this and seems to have participation by PerTronix people. Evidently when the copper wires get really old they can cause the unit to short out.
https://www.jalopyjournal.com/forum/threads/pertronix-and-copper-core-wires.391152/
Keoke
Well what they are really talking about is ageing of the insulation on the wire.
"Evidently when the copper wires get really old they can cause the unit to short out."
Uninsulated Copper conductors whether stranded or solid do not break down to ground.
What happens is the insulation on the wire will crack with age which allow the electromagnetic force if it is close to chassis-GND- to arc.
Insulation on wire is not homogeneous.
.Militarily we spend big $$$ to meet Mil-Specs that control the quality of our insulation and it is not porous free. So we test 10% of every lot we buy to those stringent requirements..
It is probably conceivable that vendors of wire have varing quality of insulation.
However, I can not in good conscience say solid wire vendors use the inferior insulation products.
Additionally, from a material perspective under identical environmental conditions ,ageing
of stranded copper wire or solid will be the same.
In conclusion, the term solid core can simply define solid copper wire or stranded copper wire.
Additionally, some of these solid core wire designs can fail internally.
K TR2/3/3A Spark Plug Gap? Triumph 4
R Plug gap for 907? Lotus 4
B TR6 Spark plug gap Triumph 5
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A TR3A Plug Gap? Triumph 6
Marvin Gruber Plug gap does make the difference Triumph 19
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
K TR2/3/3A TR3 Plug gap .032 or .025? Triumph 8
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
DNK Plug Gap. Triumph 5
X Soark Plug Gap MG 14
H Spark Plug Gap Austin Healey 3
K TR2/3/3A TR3... Mods and Champion Plug Gap? Triumph 1
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
H 73 Midget Plug and Points Gap MG 8
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
HealeyRick Plug Your Pipes! Austin Healey 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
