Spark plug gap
billspit
Yesterday I was installing new Champion plugs in the 80 Spitfire engine I have rebuilt. The book says the gap should be 0.025". Its been a long time since I've installed plugs in one of these engines, but is that correct? Seems like everything now is 0.040" or so.
Andrew Mace
.025" is correct, at least for points ignitions. Larger gaps are common nowadays with electronic ignitions, and it's possible that your '80 Spitfire (presumably equipped with some sort of electronic ignition) might benefit from a gap somewhat larger than the old .025"?
B
billspit
Once I get the engine broken in, I will be going with a Pertronix ignition. It orginally had the electronic ignition that all late Spits had.
trfourtune
to go to the big gaps, you need a HOT coil and something like an MSD, Crane, etc.
Rob
poolboy
No question,a larger gap is going to require either a coil with greater potential voltage output, 20k vs 40k OR increase dwell time for the coil to build voltage.
The draw back is that higher voltage will tend to carbonize the rotor and contacts in the dizzy cap or worse,so carry spares.
Although this article addresses Ballasted Ignition, there's something to be learned regarding the relationship between plug gap and coil potential.
https://www.vtr.org/maintain/ballast.shtml
K TR2/3/3A Spark Plug Gap? Triumph 4
B TR6 Spark plug gap Triumph 5
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
H Spark Plug Gap Austin Healey 3
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
