TR6 Spark Plug
DNK
Dave- (I guessed at your name) Do you have the Bentley Manual for this car?
sammyb
Walk into your local parts retailer (O'Reilly, NAPA, Autozone) and get some NGK BPR6ES plugs. Many of the manuals of the era spec for Champions, but Champion quality has plummeted in the last decade. I had a couple not fire at all in the last few years. Autolite is also pretty sketchy. NGK seems to be the go-to plug for everything vintage -- from Triumph TRs to Ferrari TRs.
poolboy
These are in my 73 and were in my 74..never a problem
....................................Cylinders 3 and 6....................................
YYCDave
I'll second poolboy's recommendation. I've used NGK for years with great success but the TR6 has just never seemed happy with them. I installed some RN12YC's and have never looked back. Great performance and zero fouling.
sammyb
Aside from the couple of Champions that I got that simply were DOA, I was at my friend's shop right after they discovered a Champion electrode simply fell off into the cylinder of a newer car (Hyundai or Toyota, I just can't recall what it was). It was a brand new Champion plug as spec-ed for OEM parts during the scheduled service (60K type service). The electrode just dropped off as the customer was driving her car home from the shop and brought it back in. Destroyed the cylinder. They won't use Champions again. And considering my Ferrari mechanic buddy also told me to stop using them (for the DOA issue, which had plagued him in servicing cars for his Ferrari/Alfa/Maserati customers), I can't recommend them.
Champion was bought out by Cooper in '89 and then absorbed into Federal Mogul in 1998. Since then, the brand has gone downmarket. Champions are half the price of other plugs, and the quality reflects this.
sammyb
You've sure had your share of bad luck there, sammy..
Luckily the only problems I've personally had were with the Champions on my 308 GT4 -- but I installed them after a long project to get the car running again. I was troubleshooting all over the place to figure out what was wrong with those cylinders, then it turned out to be just plugs and a little carb tuning.
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
M Spark plug heat range Triumph 4
J Spark Plug life Triumph 24
W Oil leak around spark plug Triumph 6
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
tahoe healey Champion spark plug testor Restoration & Tools 25
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
