GT6 Replacement body panels
Hoodat
Hello all,
I injured my GT6 :sorrow: so I have to replace a front wing and a door skin. They're available from Rimmer Brothers. My question: does anyone have experience with the replacement panels? Are they OEM quality; or good replacement parts (same metal thickness, corrosion resistance...); or suggested alternative sources? The exterior was in excellent shape; I want to get it back to original condition.
Hoodat
H
Hoodat
No description of the panels except for the specific application. I e-mailed Rimmer Bros. with the question; awaiting response.
Hoodat
Coalhod
FWIW 2nd on the use of BMH panels. Excellent fit and thickness. May cost a little more but savings in the long run IMHO.
H
Hoodat
Thanks for the advice poolboy, Coalhod. Rimmer Bros. support states: "these are made by BMH to original spec and metal thickness."
Hoodat
C TR2/3/3A TR2-3 Replacement Body Panels Triumph 1
Rut Bugeye body panels and replacement Spridgets 4
T TR2/3/3A TR3 replacement body panels Triumph 14
KenASh replacement body panels Jaguar 9
C Expereince with Moss motors replacement body panels MG 13
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Editor_Reid Body Number Plate Replacement Austin Healey 13
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
angelfj1 Help Need replacement body ID tag Triumph 8
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
