Rear Brake Cylinders
randy gay,this is how it reads as per moss cat. rear brake cyl. bn1-ce.221536 and sub. (hypoid axle) part# 021-159-$23.00 for bn1-bn2-bn4-bn6.----- rear brake cyl. bn1-c.e. 221535 (rear spiral axle) part# 021-160 r/h $80.00-- part #021-158 l/h $80.00 for 100's to 3000's----- repair kit part # 513-014 $30.00 you can go to www.mossmotors.com and look at the pretty diagrams as well. /ubbthreads/images/graemlins/yesnod.gif
John Loftus
Hi Randy,
If you still have your old cylinders you can have them resleeved which makes them better than new. I had mine done by Sierra Specialty Automotive https://www.brakecylinder.com/ and was very pleased with the quality. I have some pictures on my restoration website resleeved cylinders
Cheers,
John
AUSMHLY
Hi John,
You've been helping me with my restoration questions. And I'm sure I speak for everyone here, thank you for offering your expertise.
Today was the first day I took a look at your restoration website. I didn't know you had one. Wow, very well documented and excellent attention to detail.
Hopefully some day we will meet. I'd love to see your car and thank you in person for all your help. Cheers, Roger
John Loftus
Thanks Roger and Rob for the kind words. I don't really have much expertise though. Just going through my first ground up restoration and trying to learn as much as possible as I go. Most of the time I just parrot something that I learned from someone else.
Really look forward to meeting you too. Lots of nice people on this forum and hopefully our paths will cross in the near future (higher probability once I get this car on the road!)
Cheers,
John
Keoke
Naw /ubbthreads/images/graemlins/nonono.gif He ain't gonna drive to Raleigh Tenn like some other nut I know very well did.----Keoke- /ubbthreads/images/graemlins/driving.gif
John Loftus
Hey Keoke .. what are you doing here? I thought you drove up to Nelson BC?! /ubbthreads/images/graemlins/grin.gif If my Healey was ready to go, I'd be there right now! /ubbthreads/images/graemlins/driving.gif
Cheers my friend,
John
Keoke
WOT! someone tell you BC was cool in the summertime they lied!---Keoke- /ubbthreads/images/graemlins/grin.gif
Keoke
WOW!Thats great John, look up some good Healey sources while you are there if they exist. /ubbthreads/images/graemlins/thumbsup.gif-Keoke
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
CJD TR2/3/3A Early Rear Brake Cylinders Triumph 2
J TR2/3/3A Installation of rear brake cylinders for 9" brakes on TR 3A. Triumph 3
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
drooartz MGB-GT GT vs roadster rear brake slave cylinders MG 5
S TR2/3/3A Should TR3 rear brake slave cylinders move? Triumph 4
richberman What to use to grease rear brake cylinders? Austin Healey 1
J TR2/3/3A TR3A Rear Brake Cylinders Triumph 1
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
White79MGB TR2/3/3A TR3 Rear Brake Cylinders Triumph 1
I Rear brake wheel cylinders Spridgets 1
KVH General TR Rear Brake Shoe Orientation Triumph 12
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
R TR6 Rear brake wheel cylinder fitment Triumph 5
D Rear Brake Drum Nuts Austin Healey 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets BN6 rear brake pipes Austin Healey 15
nevets stuck rear brake drum Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
A rear brake drum too tight after rebuild Austin Healey 3
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M suggestions on vendor Rear brake rebuild Spridgets 15
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
K TR2/3/3A Rear brake drum won't go on? Triumph 12
RJS TR4/4A Rear Brake Hose Replacement Triumph 7
