re-packing front wheel bearings
Jer
One thing I haven't done on Midge is repack the front wheel bearings, I have always checked for play & I don't have any noise coming from them.
From what I understand if the originals are okay it's better to repack than replace as most replacements available are a bit lacking to say the least...
I have ordered new seals & repacked wheel bearings in the past on other vehicles... is there any surprises that I should be prepared for ? (opposite threads, need specialty tools etc.) or is this job like any other vehicle ?
Thanks
Jim_Gruber
Thoroughly Clean and repack. A messy job but not as bad as others on this car. As I recall something like 40 lbs on nut. Tighten until wheel starts to slow up and back off a flat. When I replaced one of my bearings had to run a little loose and then go back a week later after some run in to get torque spec right. You are either there or not with cotter pin and bolt.
And yes I was fortunate to find a set of NOS Bearings. New stuff is less than optimal.
tomshobby
New OEM style bearings are available and still being made. I purchased a set from this source and they fit perfectly in every way. In another forum this was discussed at length and a couple other sources were also found> I believe at least one of them was less money.
My web page covers much of what was found. https://smithtr6.com/bearings.htm
The following is one of the e-mail replies from the source I used.
"Hi Tom,
Please see the answers to your questions below :
On 18 March 2010 17:42, Tom Smith <tom@smithtr6.com> wrote:
Graham, that is great news.
I have been searching for these for nearly a year.
1) How many do you have?
Currently less than 10 pieces.
2) Do you or can you still make them?
We have them made specifically to order.
3) What is your minimum order?
To manufacture the quantity would be 10 pieces.
I only need two, but no one has been able to find them, including vendors and owners of these cars are anxious for correct bearings.
We can supply you 2 pieces at ÂŁ45.00 each nett.
4) Can you verify the dimensions? D = 52mm; d = 25mm; B = 15mm; and most important, r = 2mm or up to 3mm
Confirmed.
Regards
Graham
From: Graham Naughton [mailto:bearinginfo@googlemail.com]
Sent: Thursday, March 18, 2010 9:40 AM
To: Tom Smith
Subject: Re: Enquiry from the Ransome
Jer
Jer
Thanks for the replacement option Graham, after I try to pack my bearings I may need to use your suggestion ! ha ha
Jim thanks for the confirmation... just wanted to be sure there wasn't an LBC "surprise" waiting for me :smile:
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
TulsaFred Front wheel bearing grease packing Spridgets 26
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
C TR4/4A SuperPro Front Spring Packing Triumph 7
Lin Master cylinder packing pieces [shims] Austin Healey 29
F TR2/3/3A Tr3A body body mount packing Triumph 2
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
D TR4/4A distributor pedestal shim [packing] quandary Triumph 6
I Hard top packing -expandable foam Spridgets 5
D Bumper Packing Piece Austin Healey 2
smaceng BE heater valve packing spec. Spridgets 10
drooartz Packing the Tunebug Spridgets 4
T TR2/3/3A TR3A door post packing Triumph 9
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
E BE Steering Bracket Packing & Toe Plate? Spridgets 10
CraigLandrum TR2/3/3A TR3 Dzus hood fastener packing? Triumph 13
R Windscreen Packing Strips MG 1
Aldwyn Car Show Packing List Triumph 17
John Loftus Windshield packing pieces for BJ7-8 Austin Healey 9
GregW Master cylinder packing piece Austin Healey 19
M Striker Packing Plate Austin Healey 5
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
