I have a question on how far the stator tube extends beyond the compression nut on an adjustable steering column. I just replaced my steering wheel and rebuilt the trafficator. I think I pulled the stator tube toward the steering wheel (but not all the way to the nut) when I pulled the upper stator tube out. Once I figured out there was a compression nut to loosen that makes everything actually move, I got everything back together and working well. The only thing is the stator tube probably sticks out about 2" / 50mm from the nut. Is that normal? It seems right, but I didn't get a look at the compression nut end of the tube before I took it apart.
FWIW - mine's always been 1/4" in front of the nut. Bob's solution sounds great. After that's done, maybe pull the stator tube forward 1/16" so the sliding tube seats just above the bottom of the slot.
I have mine out due to messing up my steering (long story - more later) and discovered the tube is cracked radially from the bottom of the milled slot and about to break in half. When I get my new tube, will drill or file the slot with a rounded bottom to prevent this in the future.
