question on brake modification
drooartz
Just a thought -- I just did the switch to disc brakes for the Tunebug (from a 74 Midget) using standard Spridget brakes. I can lock them up with a good stomp. I certainly don't feel the need for more brakes.
bugimike
I think that big-brake kit is for the serious competition setup! Just like Drew, I converted to a Spridget disc brake setup and find it more than adequate (and cost-effective!)!
Gundy
I thought about this but I'm leaning toward 4 wheel discs instead. A friend is custom fabricating us rear disc set ups.
We'll still be all Brit in the set up.
I know the seller. Bought my BE from him. I bought my HS4s from him as well. Good guy. Check out his list of buyer comments. 100% satisfied customers, myself included.
M
mightymidget
I have a modified Bug eye that will need all the stopping power it can muster. The Bugeye has a 289 ford motor installed in the chassis..so it probably has an additional 150-200 lbs to contend with, plus higher speeds will surly be reach. the rear has a 57 OLDs rear end which I am going to switch out with a Ford 8.8 drum set up
Gundy
Holy Cow Batman! You might need this type of brakes and a chute!
:devilgrin:
This set up was invented for SCCA racing, I raced on this set up, made aluminum hubs for this set up before, and installed this set up on a few race cars, I've got plenty of experiecne with it. It more than is needed for a A series street car, but owrked well on the race cars. I can see why you would want to do this for a V8 conversion, warning they are a PITA to install, no two alike, acess to lathe and mill comes in real handy with this conversion. The ebay auction looks a bit junky/crusty for the money, I would pass, Winner Circle has the rotor/hub adapter in aluminum, and you use a MGB caliper (all MGB year models were the same) and a spitfire rotor (all years were the same as well, but don't use a GT6 rotor, they will not work for this conversion. Peter May Enginering in the UK, also offers a even higher level kit using vented rotors and Willwood 4 puck calipers, more money of course, but for sure cool, still way too much brake for the street in a normal 4 cylinder applications.
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A Brake system question - Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
K TR2/3/3A An odd brake question? Triumph 2
K TR2/3/3A Brake pad Question Triumph 3
Lin Brake hard line question Austin Healey 4
J TR6 TR6 Brake Question Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
K Midget Brake Pedal Question Spridgets 2
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D TR2/3/3A clutch/brake pedal question Triumph 4
K TR2/3/3A 3rd brake light question Triumph 3
D BJ8 brake master cylinder question Austin Healey 6
D brake drum question Austin Healey 5
JPSmit Brake Pads - question Restoration & Tools 10
roscoe Brake pad question Austin Healey 3
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
I TR6 Brake caliper question Triumph 7
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
B Another disc brake question Spridgets 10
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M TR6 Brake master cylinder question. Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
T TR2/3/3A another brake master cylinder question Triumph 16
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
sd80mac7204 Spitfire 1970 Brake question Triumph 3
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets question about brake master cylinder Austin Healey 12
nevets Question about brake bleeding Austin Healey 13
J MGB Question on the brake warning light for 78 MGB MG 6
C question on the front brake lines for BJ8 Austin Healey 2
D Question on brake rotors Triumph 3
bugedd Brake bleed question Spridgets 9
bugedd RX7 rear axle and brake question Spridgets 2
H brake/rotor question Austin Healey 28
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
D TR2/3/3A TR3 brake rotor question Triumph 4
Mowgli81 General Brake Question & repair manual Austin Healey 25
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
A Wedge 1980 TR7 Brake master Question Triumph 5
T Rear brake clyinder orientation question Triumph 4
J Question on rear brake mounting plates Spridgets 5
