TR4/4A Pricing a TR4 project car
Alfred E. Neuman
Found an early TR4 near me that's all original. Runs and drives, but needs a complete restoration to be what I want.
Test drove it last Saturday and it runs strong (needs tuning), transmission felt tight with no weird noises and no tendency to jump out of gear. No other big red flags.
No rust at all to speak of. Rockers and all floors looked solid. Usual spots behind the front wheel wells and the seam along the rear fenders/body are clean. I'm going to get it on a lift tomorrow for a good look underneath.
Only issue I really saw was the eyebrow over the right headlight has taken a lick. Doesn't look like accident damage, just like something fell on it or it got backed into. Pretty good dent and split in the eyebrow. Not sure how I'd fix this. First thought was to make a template of the curve on the good side, and make a buck out of hardwood to fit and form a repair piece for it. Or just get a used bonnet on the ebay.
How would you price a project car like this? They want $15k, which seems steep. I think it's worth in the ~$10k range.
sail
Sounds somewhat similar to my 4A. I was preparing to sell it before problems came up that need to be dealt with and hoping for $12k.
Alfred E. Neuman
Alfred E. Neuman
Thanks for the replies. I think 10k will be my soft ceiling. This will be a frame off job over the next couple of years. Should be a *relatively* straight forward project due to the lack of rust repairs, but it's still a full restoration to make it into a usable club touring and rally car for us. The fact that it's right here and I don't have to ship it gives me a little bit of wiggle room.
Alfred E. Neuman
Alfred E. Neuman
Got a nice look at the car on the lift today. It's absolutely devoid of rust. Small dent in the right of the front valance with some bondo showing through the holes they drilled to pull the valence back out. I think the hood would be much more of a hassle to fix the dented/split eyebrow than it's worth. I'd source a used one with less issues.
Right rear took a small hit and dented the fender at the tail light. Fixable with hammer and dolly but will take some shrinking to get it back straight once the metal is moved back where it belongs.
Paint is a mix of original and poor respray. Numerous dents in every panel. Easy fixes, but A LOT of hammer and dolly work and probably a fair amount of shrinking to get panels are smooth.
A PO absolutely COBBLED a radio install and mangled the brace, so I'd have to source one. Other than that, it's just a solid original TR4 that doesn't need too much to be a DD, but would need a full restoration to get it up to the car I want. Not to mention sourcing an OD trans.
I'd say Marv is right on the money. I'd really like to have the car, but it doesn't make sense to overpay for a car that's coming apart anyway.......
$10k is my firm ceiling.
François
Me, a tune up could mean other things invisible. Depending on where rust spots are, you might find a useful piece on an otherwise crappy body part. Either way, though, i wouldn't go over 8,500. G'luck with that
mctriumph
Having restored dozens of Tr's over the last 50+years, I can say that I have seen more people
buy a crap box, then a good car. If you are crazy enough to NOT put a potential buy up
on a lift for a serious rot check, may God have mercy.(the tin worms do NOT).
Todays restoration of a good example will run past 20K faster than you can write checks.
For major mechanical add 10K.
I once saw a 66 Tr4a that looked fine on the dealers show room floor, IT needed a frame and
had fiberglass rockers held in place with plumbers tape.
Mad dog
auprichard
Marv has his finger on the pulse. I would just add that, since we lost The Roadster Factory, prices elsewhere seem to have gone up a lot. So too has paint, but the cars themselves do not seem to be appreciating. But if this is a car you intend to keep and enjoy, go for it!
mrv8q
What’s the old line, you make money when you first buy the car and not when you sell it? Lots to be said for a rust-free car, but it seems like it has a lot of other needs. And with TRF down for the count, lots for you to decide! Best of Luck!
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
J General TR Wire wheel sale pricing Triumph 18
AngliaGT TR6 TR6 Pricing? Triumph 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
bighealeysource Craziness continues with 100M pricing Austin Healey 15
E Austin Healey current pricing of cars Austin Healey 20
T TR6 TR6 pricing help Triumph 16
B TR6 Need a few opinions on parting out/pricing for TR6 Triumph 8
zimmy pricing my car ....too high, too low? Spridgets 0
HerronScott Spitfire Pricing Spitfire parts for sale? Triumph 8
Creatrixx MiniCity vs MiniMania pricing British Motor Corp 20
J Spitfire 1967 Spitfire - Pricing Help Triumph 2
69MGC Buick V8 pricing question MG 2
T 1966 Accessory Pricing Austin Healey 2
G Mini Pricing British Motor Corp 8
J Jaguar X-type pricing out..29950 for 2.5 engine 4 whd..stick..would you buy this? Jaguar 16
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
