piston size
LHall
I just took of my cylinder head to start a rebuild and I was just wondering if the pistons have some mark to know if they are original or if the engine has been rebored.
if there isn't too much carbon on top, you may be able to see .010, .020, ect stamped into the top. no mark usually means standard pistons
You'd know *my* pistons aren't original!
I re-built my engine with two "scrap" engines, and it has two pistons marked "#3"!
Truthfully, the only proper way to see if an engine has been re-bored is to measure the bores with a gauge...then compare it to the specs in your workshop manual. Be sure to measure at the top, middle and bottom of the cylinder to see if there's excess taper. You can get a good idea of true measurement even if the pistons are not removed.
If you do not have a cylinder bore gauge available, or you are not able to borrow one, you may be able to rent one from a local rental agency (the rental place by me has all kinds of stuff like this).
I think he was hoping to find out without taking the engine further apart
Chuck,
I don't understand your comment. Nial specifically made this statement - "You can get a good idea of true measurement even if the pistons are not removed."
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Chuck Cougill:
<hr></blockquote>
You can if you have an inside micrometer!! Anyway, there should be a stamp on the top!! I have never seen an oversize piston unstamped!! Anyway, I would think a guy would really want to know what his bore is like instead of putting back an unknown quanity!! GOOD LUCK!!!!!
I guess Gary answered the life long question size really does matter
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
S GT6 HELP! I need 1 GT6 piston! .020 over size. Triumph 8
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap đź‘‹ Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
T General Tech How loose can a piston liner be? Triumph 2
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
M Healey 100-4 Piston Crown Clearance needed to Cylinder Head Austin Healey 3
oxford piston rings Austin Healey 4
T TR2/3/3A caliper piston stuck Triumph 12
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RedTR3 TR2/3/3A TR3 Piston Sets Triumph 10
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
