OD unit operating piston rings?
Jake
OK, I spent part of the day cleaning up the internals to the BN2 OD unit, this included some hot tanking and evapo-rust soaking. I managed to get most of the piston rings off in one piece but one of the operating piston rings broke, one of the single ones underneath the double ones. Since I'm more familiar with LH type OD units a la MGB, I wondered if anyone had replaced the metal rings on the early pistons with rubber o rings. Anyone?
I checked them with my caliper and the groove dimensions are spot on for the Parker recommended size for a 1/8" o ring on a 1.373" plug (piston). They're so correct that it seems as though they were designed to run o rings.
This groove size takes an AS586A-216 o ring in whatever desired material.
Anyways, if someone has experience with this, please chime in. I don't see why it wouldn't work, designing mechanical stuff with o ring seals is part of what I do where I'm currently employed.
If no one knows, then I'll be doing the experiment.
Here's a shot of some of the bits, finally managed to get the input shaft nut off and press the bearing off, ready for a new one.
You can get replacement metal rings, and you can also get later model (O-ring style) pistons to put into the earlier units. Personally, I wouldn't swap them in partsies__only wholesies...
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
T Lucas Flasher Unit Austin Healey 5
P Flasher Unit Austin Healey 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
B General MG 77 MIDGET Gas tank sending unit MG 1
BoyRacer Fuel Tank Sending Unit Austin Healey 3
FlyingCat Spitfire Fuel Sender Unit Triumph 2
B Flasher Unit Austin Healey 1
BN6_2197 How does the flasher unit work Austin Healey 4
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
R TR2/3/3A Flasher Unit, A Clue? Triumph 11
T TR2/3/3A Question on steering idler unit Triumph 2
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
M TR2/3/3A Identification of Rack and Pinion Unit Triumph 3
F Wanted Transmission and OD unit Austin Healey Classifieds 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
S TR2/3/3A gauge sending unit Triumph 2
G TR4/4A Flasher Unit...VERY hot Triumph 10
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
B TR2/3/3A Flasher Unit operation Triumph 4
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
TulsaFred Fuel Sending Unit Spridgets 4
Got_All_4 TR2/3/3A Removing the J type unit from the gear box Triumph 24
George Zeck Sending Unit is toast ...... Spridgets 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
R austin healey fasher unit Austin Healey 1
rjc157 fuel tank sending unit Austin Healey 4
H TR2/3/3A Manual for the Laycock de Normanville Overdrive Unit Triumph 14
R Fuel sending unit Austin Healey 4
V Fuel Gauge Sending Unit Austin Healey 3
B Sending Unit Adjustment? Spridgets 11
C TR2/3/3A fuel sending unit Triumph 9
H Up-dated Flasher Relay Unit for Austin Healeys Austin Healey 1
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
R 100-4 flasher unit buggin' me Austin Healey 2
D TR6 Sending Unit Triumph 1
PAUL161 MGB Replaced sending gas gauge unit. MG 5
Z Bosch Fuel Distribution Unit TVR 5
