Bosch Fuel Distribution Unit
zgu954
I have a 1985 TVR 280i that has a fuel distribution unit with the valve in the unit stuck in teh up position. Anyone have a suggested fix for this problem?
Regards,
Leonard
Platinum
Bosch CIS, yes?
The head can be taken off the distribution unit and with a soaking in mineral spirits it may loosen up the "plunger". My CIS books are locked away in the attic, but the units aren't all that complex.
Not TVR specific but will give you some insight: https://www.google.com/url?sa=t&rct=j&q=bosch%20cis%20fuel%20distribution%20unit&source=web&cd=6&cad=rja&ved=0CEgQFjAF&url=http%3A%2F%2Fwww.porsche928forums.com%2Fdownload%2Fmanuals%2FCISRebuild.pdf&ei=5kXPUYu4GYny9gTytIH4AQ&usg=AFQjCNH3_E6K45yVbwQZFzmGM45tqp8hBg&bvm=bv.48572450,d.eWU
Be aware of the O-ring advice after you get the plunger out. And report back here if this helps, please?
Platinum
Deleted member 8987
I have had some experience with these types of units, altho not TVR specific by any means.
My first thought would be, that ain't all your problems!
A little more info might help.
Like, was it running just fine, bombing up the hillclimb, and jammed, or is this something you dragged out of 20 years of storage?
If stored, and you have moisture/corrosion issues, be prepared to find a rebuilder.
If it happened in use...and specifically backfired....might just be the plate not centred in the bore and jammed. Look for light around the plate.
I always hated those things..of course, I generally got them when they were brought in with emissions failure issues. And very high miles.
Dave
Z
zgu954
Bosch CIS, yes?
Not TVR specific but will give you some insight: https://www.google.com/url?sa=t&rct...K45yVbwQZFzmGM45tqp8hBg&bvm=bv.48572450,d.eWU
Thanks for the manual. It is very helpful. I look forward to getting the 280i back on the road.
Z
zgu954
Thanks so much for the manual. It is very helpful. I look forward to getting my TVR back on the road. Regards, Leonard
Z Bosch Fuel Distribution Unit TVR 2
K Bosch Fuel Pump Problem Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
7 I screwed up - Bosch VE pump. Other Cars 1
7 No more Bosch tools for me Restoration & Tools 4
JPSmit Bosch Coil question Spridgets 14
A TR2/3/3A Bosch ruled the day Triumph 2
aeronca65t Spitfire Bosch distributor in Spitfire? Triumph 3
hondo402000 Bosch alternator conversion Triumph 3
DrEntropy Bosch Plat Plus NLA? Other Cars 6
SCguy Bosch Fog Light Cover! Triumph 1
SCguy Wedge TR8 Bosch Fog light covers Triumph 8
T On a positive note - new Bosch alternator rocks! Triumph 21
T Paul - did you change any wiring for the Bosch? Triumph 3
tomshobby Bosch alternator Triumph 30
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
bmurphy7369 Bosch Blue Coils... for older OPUS systems? Jaguar 3
Woodie bosch spark plug wires Spridgets 5
rodesmg bosch sparkplug Spridgets 1
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
aeronca65t Bosch Graphics Other Cars 4
LastDeadLast Bosch Alternator Wiring Question Triumph 1
O 110-amp Bosch Alternator Upgrade MG 47
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
