Bosch alternator
tomshobby
I am having some trouble finding a Bosch 55 amp alternator from a 1980 Ford Fiesta.
Has anyone had experience with a 70amp Lucas? I have found a source for a new one that would be a direct fit.
I could fit a Delco but am short on time because of a family happening and other projects.
Your thoughts are appreciated.
Brosky
Tom,
Precision Parts & Re-Manufacturing
https://www.pprok.com/
Very good on giving specs at tech support. They do NOT sell direct, but will tell you of a local (to you) distributor to order it, or buy if in stock.
kodanja
I put a Bosch 55 amp in mine!
this is where mine came from, try this: Bosch alt.
DNK
Tom- have to be careful. Not all come with the pulley. The one Paul posted does.
kodanja
Well fer that price you may as well have them mail it to ya....lol'
TR3driver
Great Pumpkin - R.I.P
BTW, what Lucas is that? The ones I'm familiar with are larger diameter than the stock alternator. Possibly the TR6 can accomodate them, but a Stag doesn't unless I make different brackets.
tomshobby
tomshobby
Hi Randall,
The supplier called this morning and told me about it and that it was the same dimensions.
We did not have much time to talk because I was on the other line talking to my brother about the fire his kids had this morning.
I will try and get more information about it and let you know.
I agree totally, it just seemed strange when I talked to them last year that they don't have counter sales considering the size of the population.
Brosky
I have that info somewhere too Randall. I think it was for a 75 or 80 amp. I'll look when I get home tonight. I had already bought mine, or I would have made the switch to that one.
tomshobby
tomshobby
I just got off the phone with the shop that I use for rebuilding alternators. Mike said he has a core for one of these new series Lucas alternators and I am going to drive my TR6 there in the morning to check the fit. He told me they use these for use on fork lifts and other industrial equipment. He also said he visits a forum for rebuilders and he has not seen anything about anyone having problems with them.
I will let you all know what I find out.
Brosky
Tom,
That is exactly how I found mine, through a Bosch industrial listing. Clocking of the rear housing may need to be moved 90 degrees, but the connector should be the same according to the diagram that I had.
Brosky
Here is the other source that I found AFTER I had mine on the car. There was a thread on this a while ago, but I can't find it. Anyhow, here ya go:
https://www.bbbind.com/index.cfm/FuseAction/products.Lucas/index.htm
With these higher 70-80 amp units, anyone who installs it BETTER plan to run a new wire back to the starter, in heavy gauge quality cable.
GreenOne
In addition to that all the wiring would be in question as the original was designed for around a 40 amp potential, now you would be looking at a 70 to 80 amp potential which is basically double the original !!
Brosky
GreenOne,
That is what the previous thread from over a year ago got into. Much debate about it, but the starter wire is the minimum. I only put this up for reference for Tom, not to relive that again. But I do agree with you, as I've already added the Masters Headlamp Wiring Harness due to the PL700 Halogen lamps.
GreenOne
Paul, I know you know the issues that was not meant to minimize your statement just to point out to the less knowledgeable that more power is not necessarily better, especially if the freaking wiring is 35 years old.
Brosky said:
GreenOne,
kodanja
hee hee hee!
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
hondo402000 Bosch alternator conversion Triumph 3
T On a positive note - new Bosch alternator rocks! Triumph 21
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
LastDeadLast Bosch Alternator Wiring Question Triumph 1
O 110-amp Bosch Alternator Upgrade MG 47
7 I screwed up - Bosch VE pump. Other Cars 1
7 No more Bosch tools for me Restoration & Tools 4
JPSmit Bosch Coil question Spridgets 14
A TR2/3/3A Bosch ruled the day Triumph 2
aeronca65t Spitfire Bosch distributor in Spitfire? Triumph 3
Z Bosch Fuel Distribution Unit TVR 5
Z Bosch Fuel Distribution Unit TVR 2
DrEntropy Bosch Plat Plus NLA? Other Cars 6
SCguy Bosch Fog Light Cover! Triumph 1
SCguy Wedge TR8 Bosch Fog light covers Triumph 8
T Paul - did you change any wiring for the Bosch? Triumph 3
bmurphy7369 Bosch Blue Coils... for older OPUS systems? Jaguar 3
Woodie bosch spark plug wires Spridgets 5
rodesmg bosch sparkplug Spridgets 1
aeronca65t Bosch Graphics Other Cars 4
K Bosch Fuel Pump Problem Triumph 4
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
