caliper piston tool
TomMull
LarryK
Looks good. Have as many caliper, brake tools I can get. Never had a problem since. Price is decent.
glemon
I get the part about spreading the piston, but looking at the tool I can't visualize how it would help getting the pistons out, a little air works great. I have never had much trouble getting pistons out, the tricky part, for me at least, has been fitting the rubber dust shield to the piston and caliper.
TomMull
TomMull
I don't know if, or how it works, either and was hoping someone was familiar with it. The pistons do come right ou if they have not been sitting for more than 40 years. I've tried compressed air, compressed grease, heat (boy is that unpleasant) with only limited success. Perhaps I have all the bad ones. Or maybe someone has another trick? Tom
BigGreen
Looks like the two aluminium "claws" can be turned away from each other inside the piston
It would give an arm to "wiggle" the priston out
DIY project for a winter evening ;-)
Platinum
Yup.
The Allen wrench is used to widen the jaws (with the threaded rod) to grab the I.D. of the piston, the longer arm then gives you a mechanical advantage to twist the piston back and forth as you retract it from the caliper body.
PAUL161
Tom, can you get the piston out enough to get some weasel pee on it to soak around the piston? Possibly get some in the fluid chamber? If you could get some of that stuff in there tapping the caliper lightly with a hammer to shock it and let some travel around the piston might help. PJ
TomMull
TomMull
Good suggestions, Paul, but the piston has become one with the caliper. I do have some good ones but would like to resurrect a couple that are completely stuck. Probably the bores are beyond repair even if I could get them apart. Tom
Keoke
"weasel pee"-----:lol:
I disassembled a set of calipers from a car that sat nearly 30 years in a field. What I ended up needing to do was, after breaking them in two parts, was heat the piston until the remaining fluid steamed out the holes, then tossed the halves into a bucket of cold water. Three of the sides only needed this once, the other needed it twice. But in all cases broke the postons free and I was able to twist them out.
TomMull
TomMull
Thanks, Mike. Interesting. I'll give that a try in the spring. Nothing to lose. Tom
Does seem to work since a professional brake shop gave them back to me saying they couldn't get them out. But be aware once they go into the water you're committed since the colling will pull water into the passages and piston chamber so the pistons will need to either come out so you can dry everything or rust will flash over inside. But as I said, it did work for me. Took 2-3 hours to do the four sides of the pair.
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
T General Tech Brake caliper - piston stuck Triumph 4
T TR2/3/3A caliper piston stuck Triumph 12
RJS Frozen Caliper Piston Triumph 15
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
TexasSprite Bugeye caliper piston orientation? Spridgets 4
D Midget caliper piston positions Spridgets 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
Walter74 Caliper Alignment Austin Healey 7
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
B TR2/3/3A Caliper brake line Triumph 10
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
K TR2/3/3A Brake caliper hold bolts? Triumph 1
K TR2/3/3A 62 TR4 Brake caliper? Triumph 5
mrv8q TR2/3/3A Caliper “dog bone” shims Triumph 5
I TR6 Brake caliper question Triumph 7
TomMull TR2/3/3A Caliper bridge pipe Triumph 3
T Spitfire Caliper bolts, again Triumph 2
C TR6 Leaky brake caliper Triumph 6
B BJ7 Caliper rebuld Austin Healey 11
Jim_Stevens TR2/3/3A Brake caliper corrosion Triumph 5
RandyInUtah TR2/3/3A Caliper problemI have spent hours researching all of my manuals Triumph 9
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
B TR2/3/3A Can a caliper be freed up without a rebuild? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
F BJ8 caliper rebuild??????? Austin Healey 13
J General Tech Stainless-steel caliper pistons Triumph 8
steveg Sourcing Custom Caliper Hoses Austin Healey 2
HealeyRick Brake Caliper Upgrade Austin Healey 120
M_Pied_Lourd TR2/3/3A Brake Caliper Piping Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
Michael Oritt GT6 GT- 6 Brake Caliper/Mounting plate information needed Triumph 4
I TR6 Caliper help please Triumph 2
glemon TR6 Toyota Caliper Conversion Triumph 28
T TR6 Brake caliper lock after some driving Triumph 3
steveg Rear caliper seal clamping ring Jaguar 1
R BJ8 Front Caliper Seal Austin Healey 1
steveg Caliper cleanup question Austin Healey 12
