TR2/3/3A caliper piston stuck
tomnanney
Anyone have a good way to free a stuck caliper piston? The caliper is off the car. One came out easily with compressed air , but the other one won't budge!
Thanks
tom
Geo Hahn
If you reinsert the removed piston and clamp in place you should be able to apply some serious pressure to the opposite side. Some possible source of the pressure:
Air -- easiest but possibly least effective.
Hydraulics -- reconnecting to the car's brake line and using the pedal, a lot of pressure but may be impractical if much of the rest of the system has been removed or is non-op.
Grease Gun -- never had to resort to this myself but some have adapted a grease gun fitting to the caliper inlet and pumped grease forcing the piston out. Messy but at this point that is possibly not a concern.
Whatever you do - keep fingers and other parts out of the way.
trglory
Having one out gives you the extra room you need. Press the stuck caliper back in with a C-clamp and a socket. If it is cocked, press first at the high point.
Joe
Darrell_Walker
I saw this on the Moss Motoring blog recently:
https://www.mossmotoring.com/frozen-brake-caliper/
Pretty slick idea, basically block of the hydraulic connection on the caliper, fill with fluid, then use a clamp to press the free piston in, which will force the stuck piston out.
mrv8q
Grease gun worked fine for me. As Geo says, messy, but effective!
sail
A bicycle foot pump got mine with the other piston held in the caliper by a board and 2 C clamps to the workbench.
Not messy but to clamp it on the bleed valve had to cut the end of the hose off.
T
tomnanney
thank for all the posts. I put the other piston back in and clamped it down. Used compressed air and the other one came out! Now the rebuild starts!
tom
sp53
If I remember correct, I took one of those zerk fittings offthe lower wishbone because the threads are not cut on a taper like most zerkfittings and somehow hillbillyed that on a grease gun then plugged the other side with a piston and itcame right out.
dklawson
I REALLY like that idea. I have known people to use the grease gun method before but that seems like it would need an awful lot of chemical cleaning later. Closing the caliper off and using the trapped brake fluid sounds so much neater. However, I hope I don't have to try this anytime soon!
TomMull
T General Tech Brake caliper - piston stuck Triumph 4
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
TomMull caliper piston tool Restoration & Tools 11
RJS Frozen Caliper Piston Triumph 15
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
TexasSprite Bugeye caliper piston orientation? Spridgets 4
D Midget caliper piston positions Spridgets 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
Walter74 Caliper Alignment Austin Healey 7
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
B TR2/3/3A Caliper brake line Triumph 10
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
K TR2/3/3A Brake caliper hold bolts? Triumph 1
K TR2/3/3A 62 TR4 Brake caliper? Triumph 5
mrv8q TR2/3/3A Caliper “dog bone” shims Triumph 5
I TR6 Brake caliper question Triumph 7
TomMull TR2/3/3A Caliper bridge pipe Triumph 3
T Spitfire Caliper bolts, again Triumph 2
C TR6 Leaky brake caliper Triumph 6
B BJ7 Caliper rebuld Austin Healey 11
Jim_Stevens TR2/3/3A Brake caliper corrosion Triumph 5
RandyInUtah TR2/3/3A Caliper problemI have spent hours researching all of my manuals Triumph 9
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
B TR2/3/3A Can a caliper be freed up without a rebuild? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
F BJ8 caliper rebuild??????? Austin Healey 13
J General Tech Stainless-steel caliper pistons Triumph 8
steveg Sourcing Custom Caliper Hoses Austin Healey 2
HealeyRick Brake Caliper Upgrade Austin Healey 120
M_Pied_Lourd TR2/3/3A Brake Caliper Piping Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
Michael Oritt GT6 GT- 6 Brake Caliper/Mounting plate information needed Triumph 4
I TR6 Caliper help please Triumph 2
glemon TR6 Toyota Caliper Conversion Triumph 28
T TR6 Brake caliper lock after some driving Triumph 3
steveg Rear caliper seal clamping ring Jaguar 1
R BJ8 Front Caliper Seal Austin Healey 1
steveg Caliper cleanup question Austin Healey 12
