MikeAH100M
Anyone know what the proper amount of movement/lash there should be between the diff pinion gear and ring gear on a bugeye? Removed the diff while I was checking on an axle issue and noticed that I can move the driveshaft flange/pinion about a 1/16" and get a noticeable "click". Both gears look good, no uneven wear, no chips, nice polished appearance. The differential is also very quiet at all speeds - no hum like I have noticed on some other spridgets so I'm thinking the movement is OK but wanted to check in with others who might know more about this.
