3.54:1 Ring & Pinion...
Just a heads up to let you know that Mike Lempert is taking deposits on another batch of gearsets.
Delivery is estimated at five months, but understanding the operations and processes involved, that seems reasonable to me.
Advance planning for next winter's project list!
Mike's E-mail is: mlempert@bellsouth.net
Now if I can decide on a positive traction unit, I'll be all set...
Dave Russell
Yoda - R.I.P
Randy,
I sent a deposit to Mike L. about 11 months ago. In the mean time I got a 3.54 pumpkin from a Austin saloon & installed it. Would never go back to the 4.11 for road use. If & when the Lempert gears arrive I will either install them in the 4.11 pumpkin or just keep them around as spares in view of the likely future shortage. Mikes price is quite a bit lower than the other couple of gear vendors who offer the 3.54 ring & pinion.
Dave Russell
Yoda - R.I.P
Thom,
I don't really know which cars have the 3.54 axle. I got mine from Earl Kagna in B.C. He had a couple of them at the time. I'll bet that Sherlock would know such a thing. The axle is the Austin A90 type.
I used the entire pumpkin. Just bolted it in. Earl had actually run & tested it for leaks & noise before the sale.
For me it was worth the effort. I'm not exactly in the flat land. As you say, first gear was so low as to be practically useless. It now works as a very good gear. It will still burn the tires on a start, just takes more throttle. What I really like is being able to cruise at 78 mph & turning 3,000 rpm. (28% overdrive) The top speed is actually higher in direct fourth than in OD, but I don't run top speed very often.
Sorry, I just go by the tach & mental notes for speed. Around 2,200 rpm is 60 mph in OD. 2,600 is 70. 3000 is about 80. The plan is to have the speedometer recalibrated by MOMA (Motor Mart), New Mexico when I'm in the mood. Margaret told me that a gear change inside the speedo would do the trick.
PS,
I found a bit more info on the BMC C series axles;
3.54 is marked 39/11
The differentials fitted to the Isis is of the C-series type.
Here is a brief list of which ratios were used, and where:
4.1:1 Isis, Wolseley 6/90, Austin A90 c.19mph/1000rpm 15" rims
3.9:1 Austin A99-A110, Wolseley 6/99-6/110 with Manual Transmission ?
3.54:1 Austin A99-A110, Wolseley 6/99-6/110 with Automatic Transmission
[ 02-04-2004: Message edited by: Dave Russell ]</p>
ThomP
Dave Four questions:
Which Austin Saloon(s) have the 3.54 gears?
Did you use the entire differential or just the ring and pinion?
Is is worth the effort? I have the in-between 3.80. 1st gear isn't really useful here in "flatland".
How did you address the seedometer issue? Please don't tell me you do the math in your head as a mental exercise. I already have a Mini with a KPH speedo, so that exercise is familar.
Thanks
Thom
BOXoROCKS
Well... I have a 3.54 gear set in my VandenPlas MK II Saloon that I could be tempted to remove. For the right offer. I would have to move the VDP from the back of my property, and clear a space in my shop for the job. So I would hope to get offers reflecting the work involved. Just thought that I would throw this out, if there was any interest. The VDP is the Austin Healey type 2912 CC engine, with auto trans, and 14 inch tires.
Michael Oritt
I had a ratio adaptor box made by a local speedo shop. It is installed in the cable just behind the dash with another short length of output cable going to the speedo head. It cost me about $150.00 installed.
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
T How do I clean sand out of a ring & pinion? Spridgets 2
JAV 3.5 ring and pinion Austin Healey 18
P Identifying a Ring and Pinion Austin Healey 8
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
K TR2/3/3A Ring and Pinion Wear? Triumph 11
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
histerical Ring and Pinion Spridgets 8
B Ring and pinion question Austin Healey 29
aeronca65t Ring & Pinion Spridgets 8
R Installing pinion and ring gear Austin Healey 11
MikeAH100M Pinion/Ring Gear Lash Spridgets 2
A 3.54 Ring and Pinion Austin Healey 63
TulsaFred 3.90 ring/pinion Spridgets 24
I Correct ring and pinion gear ratio for Bugeye? Spridgets 5
Ed_K Used ring and pinion set for sale in classifieds Austin Healey 0
B spridget ring and pinion.. what type Racing 0
B Spridget ring & pinion What year? Spridgets 11
H 3.54 Ring and Pinion Austin Healey 16
Dave Richards 3.54 ring and pinion gear Austin Healey 13
C Ring and pinion question... Triumph 4
sail TR4/4A Piston Ring Question Triumph 6
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
DrEntropy MGB Ring Gear Roulette MG 12
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
sundown TR6 Proper ring gaps Triumph 6
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
I TR6 Aluminum trim ring band removal Triumph 5
T TR4/4A Attaching headlight trim ring Triumph 6
D BT-7 tri-carb ring gap Austin Healey 10
bfitz Zenith Stromberg O ring question Other British Cars 8
J TR6 Ring gear repair Triumph 13
KVH General Tech Hastings Oil Ring Triumph 13
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
JPSmit Question four - headlight trim ring Spridgets 9
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
