Painting,I knew better
Winston
Just looking for some reinforcement of a stupid decision I recently made.
Let me begin in 1978 when I decided to paint our 1963 VW Microbus(wood paneling, ice box and fold down table).
Well I painted the bus a sporty green and swore I would NEVER paint an automobile again.
This past month I forgot that pledge and did just a little touch up.
I was in primer 2 weeks and am now thru my second 600 grit wet sand.
It's not right , nor will the areas painted ever match the other panels unless it sit's in the garage under an old tarp for 20 years.
This is just a bit of a rant because of a lesson forgotten from many years ago.
Leave the paint to the pro's.
Bugeye58
/ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/nonono.gif
Consider that a reinforcement of your decision to paint!! /ubbthreads/images/graemlins/grin.gif
Did you have the paint mixed to color match, or just go with the original formula?
Jeff
W
Winston
Ole Ruby is signal red. One of the local national suppliers sent me to their paint guy. We went to the parking lot and he cleaned a small area and scanned it with a hand held scanner about the size of the million watt hand held light.
We went back in and he set the device into a port of some sort and the computer took over.I should have known better , I have the original formula for signal red, the previous PO had repainted and he missed the mark.
So much for technology, sorry Basil.
Bugeye58
Winston, I've had very good luck with the color matching guns. I've used both PPG's and Martin-Senour's on old paint and had a good match.
The ones I used gave a percentage number of the match to an existing paint code,along with the formula of the closest match.
Red is a tough color to match, however. That's where match panels come in handy.
Jeff
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
drooartz General Tech Painting my Rostyle wheels MG 7
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
D Wheel painting frustration Spridgets 25
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
