Paint touch-up - Duplicolor equivalents?
NutmegCT
My 1959 Triumph was repainted "signal red" by the PO about five years ago. Not the world's greatest paint job, but at least it's holding.
There's a 1/2" circular popped paint bubble on the LR wing. No rust underneath - just shiny steel and primer.
I want to sand down, prime and repaint (rattle can).
Is there a way to find the Duplicolor equivalent to Signal Red? Duplicolor's website doesn't show that name, and I can't find an "equivalent table". Just taking cans off the store's shelf and holding up to the car is a bit dicey, especially with variance in the can top, and "wet vs dry" issues.
Thanks.
Tom
A
aerog
Duplicolor (and others) are designed to match manufacturer's colors but you're going to be really lucky to find anything to match a repaint unless they used a stock color from a modern manufactured car (even then red isn't the easiest to match).
I got lucky on mine, red from a late 90s Windstar van is almost a dead match. Close enough for little nicks, but not even close to what the color actually is.
roofman
Healeysince59
Drive the car to a good body/paint supply huose and they can do a computer match and load it in rattle cans. Usually they have a 2 or 3 can minimum but it's your best shot at a match.
Marv J
Platinum
With that as a problem I'd be more inclined to:
A) Have an automotive paint shop match the color. Have a half-pint mixed.
B) Build it to the edges using a sable artist's brush, several applications.
C) Wet sand (with a block) to height of existing finish with #600~#800.
D) buff, wax.
Trying to flatten and spray the area is going to be a real pain if you only have "rattle-can technology".
NutmegCT
NutmegCT
Doctor -
Could you give some details on step D: what specific products/techniques would you use for the post-sanding buff work?
Thanks.
Tom
T
Tinster
Tom,
I'm in the process of tackling all the tiny scratches
and paint dings from the 2 year restoration.
What Doc posted about layering is my method. I had to
pay $125 for a computer matching color quart locally but
still cheaper by far than a professional paint shop touch up.
I use tiny sable brush, dry 48 hours, #800 grit wet, auto
polishing compound wet, marble polishing paste (#4Kto6K
grit?), more layers with same process until the scratch
is filled in. I final it with turtle wax.
An almost perfect blend from 2 feet away.
d
LarryK
If you go to a reputable paint shop that fills rattle cans, they can mix your signal red in a rattle can for easy dispensing. You can then sand ,prime and fill , whatever you need and paint. You will need to use the rattle can within a day of filling, though. Not as expensive as it sounds. Take the car with you, they can then match it perfectly.
Platinum
NutmegCT said:
Doctor -
Thanks.
Tom
Once the "spot" is level, polishing compound (NOT "rubbing" compound) on the area with some elbow grease and wax after that. If the metal underneath is undamaged and the paint match is good it should take a maginfying glass to detect the repair, not a two foot distance. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
It's like learning to use "SpotTone" on photo paper... practice on a place under the front bumper first. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
JPSmit
another thought is the companies that are springing up to repair minor dings - My wife was lightly rear ended and I recall it was about $200 to fill the scratches and repaint the bumper.
Rut MGB Pale Primrose touch up paint MG 4
AH67 General TR Touch up Paint 11/PAA Black Triumph 2
Marla TR4/4A Touch up paint Triumph 3
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
B MGB Touch up Paint? MG 2
F Source for Touch Up Paint for Primrose Yellow? Triumph 3
RAC68 Old English White Touch-up Paint Austin Healey 8
G MG touch up paint supplier finally! Spridgets 14
N Touch up paint!!? Spridgets 8
T Touch-up paint over original factory paint Triumph 8
R Touch up paint help please Triumph 11
6 Touch Up Paint Q's Austin Healey 6
T Paint Touch Up Jaguar 4
J touch up paint, . dry time affect on color Austin Healey 11
S Touch-Up Paint Triumph 5
R Source for spray cans of touch-up paint? Triumph 12
Musicman Touch-up Paint Triumph 8
78MGB Touch Up Paint MG 3
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
