Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
So the oil did not look like a milk shake after all? And there was no crud in the oil? I would take the thermostat out and see what happens and I would look for a plugged radiator. At 200 miles the oil should still be clean.
Radiator was re-cored prior to being installed, but worth checking since maybe something came loose in the block water passages. There was some red-ish pebbly material on the radiator cap.
I've had it happen in 4.3 Blazer and yes it does look like a milkshake when mixed with oil. And hard to drain out as well. You are fortunate it did not get into the oil. How did the combustion gas test turn out. That test will confirm very quickly if the head gasket is leaking and over pressurizing the cooling system.
Hi guys - slow in providing an update on this but the news is not good.
I finally got around to pouring the oil I drained out of the 4a and after it had sat for last 45 days or so it clearly separated and there was crud in the bottom of the trays (I used several to drain the oil into) and there was a clear separation of the oil and coolant in the last one I poured into the larger tray.
Apparently the oil will not always froth, so be aware.
Maybe you caught it before the oil and coolant had a chance to mix and milkshake. That would be good news for your bearings, you never said how the combustion gas test turned out. That may be moot now that you found water in the oil. Pull the head and replace the head gasket.
BTW, the original aluminum plug in the top of the head, per Moss Tech Support, is 1 inch diameter and has 14 threads per inch SAE, and is 3/8 inch thick. It is not pipe thread.
Bob
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
