New instrument lamps
Nelson
I have a new wiring harness from AH Spares. The lamp sockets for the tach and speedo have a traditional screw socket for each and also a different type of socket for the second lamp in each. The second sockets appear to take bulbs with flat rather than round bases. The connections are adjacent to each other in the sockets. My catalogs only show screw-in or bayonet type bases for the lamps. Should I just solder the old lamp sockets onto the new wires or how do I get lamps to fit the new sockets?
jlaird
That is exactly what i did in a couple of places.
dklawson
Does the socket look like it would accept a bulb like that shown in the link below?
https://shop.wemoto.com/pictures/bulbs/capless.jpg
The last harness I bought had no screw in bases at all and took this kind of bulb. I had no trouble finding lots of bulbs to choose from at my local auto parts store.
You could solder the old screw in bases to your new harness if it's important to you to keep that part of your car original. However, it's a part of the car that only you are likely to see and the wedge base bulbs are readily available. The screw in lamps have to be ordered from the usual host of British parts suppliers.
Nelson
Nelson
That lamp would fit into my sockets. If my local car parts place can supply a bulb for my sockets I'll go that route. I wouldn't have any problem, though, with soldering my old sockets into place after making sure the contacts are clean.
Bone
Member
I had the same issue with my harness from Moss. My local store was able to get me bulbs that fit.
jvandyke
I'm still using the old school stuff but I want brighter on the tach and speedo. I "modded" the fuel and oil/temp gauges and they're nice and bright at night but the main two are terrible, what's the easiest way to brighten these guys up? get some LED bulbs or what?
(I'm currently redoing a stock dash so now's the time to "fix" this)
BTW the harness is new (though older stock) and I've cleaned up every connection. Could be the wrong bulbs though, there was an issue with an order last year......I better check I guess...
theleisure
Bronze
I bought some led bulbs (I think they're called E9's) for my gauges and had mixed results. They're way brighter, WAY brighter, but the light is a cool blue instead of warm yellow. I recommend you stick with the yellow. You could drill another hole behind the tach and speedo and install a second light if you need more light.
jvandyke
Thanks, I hate the phoney LED color as much as the dimness. I'll use good old incandescence with more POWER or something.....foil, double 'em up, higher wattage....something
JPSmit
One way to brighten them up some is to bypass the dimmer switch (when would you dim them anyway) also, throw in an inline fuse
jvandyke
no rheostat on '63s though, lucky they stopped using candles for illumination in '61
B instrument led lamps Austin Healey 12
edkap2002 TR6 Brighter instrument lights? Triumph 0
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
LAW75 Instrument Panel Lights Austin Healey 9
bighealeysource LED Instrument Lights Austin Healey 12
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
Crankshaft TR2/3/3A Instrument troubleshoot Triumph 7
steveg Improved Instrument Lighting Austin Healey 2
Crankshaft TR2/3/3A Instrument panel cleanup Triumph 4
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
Gerald_Gordon TR4/4A TR4 instrument panel Triumph 7
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
S Instrument Panel Lights Spridgets 6
R TR4/4A Question about cleaning instrument faces Triumph 8
MGTF1250Dave T-Series TF Dash Instrument Panel Studs Size MG 2
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
CJD General TR Instrument Faces Triumph 111
Jim_Gruber Instrument Bezels for BE Instruments Spridgets 4
Gerry M TR6 Instrument panel light bulbs Triumph 1
L Instrument O rings and switch plate mounting Austin Healey 4
Nelson Instrument bulb replacements Spridgets 14
T current instrument rebuilding info from Nissonger Austin Healey 3
M TR4/4A tr4a instrument knob removal? Triumph 9
T XKE Series 2 Instrument Panel Jaguar 2
M Instrument lights, etc. Triumph 8
AH100M 100/4 Instrument panel silver paint Austin Healey 5
Tinkerman TR2/3/3A TR3A Dash and Instrument Cluster Installation Triumph 11
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
Tinkerman Instrument Cluster Assembled, YEA ! Triumph 22
Tinkerman TR2/3/3A Instrument Cluster TR 3A Triumph 14
J TR2/3/3A TR3A instrument restoration Triumph 11
HerronScott TR4/4A Smith's Instrument List for TR2-4A? Triumph 1
Tinkerman TR2/3/3A Instrument Panel TR3, Question about back. Triumph 29
T MGB MGB Instrument Lighting MG 7
prb51 TR2/3/3A TR3 instrument lights Triumph 4
J Removing Healy wood instrument panel BJ7 Austin Healey 3
HEALEYJAG BN1-instrument light wiring harness Austin Healey 0
B What is the color inside the instrument. Austin Healey 2
10musketeer Cleaning Instrument Faces Restoration & Tools 1
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
jjbunn Instrument Dial Rims Triumph 12
Tinkerman TR2/3/3A TR3 Instrument Glass Triumph 5
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
PAUL161 Instrument Bulbs MG 12
S Spitfire 74 Spitfire instrument panel, Walnut or Teak? Triumph 5
M 87 XJ6 Instrument Problem Jaguar 3
2wrench TR6 Instrument & other bulbs for TR6 Triumph 5
