Bench Testing a Wired Instrument Cluster
Tinkerman
Afternoon all! I needed a ground screw for my instrument cluster, found out through the forum it is a BST not an American thread. Forum Member Marvin Gruber offered to fix me up with one and despite the best efforts of the USPS, managed to get one to me. First one got punched out of the envelope by the USPS. They tried hard to do it to the second one but Marvin foiled their best attempts by using thick card board. Thanks Marvin!
Anyhow the instrument cluster is all wired up and ready to be installed. I was wondering if there was some way that I could bench test it before I install it? I have visually checked it against the wiring diagram as I was doing it and after I finished it. I also checked continuity as I was hooking up each wire from the wire harness.
Has anyone bench tested one or have any suggestions on how I could/should do it?
Thanks, Tinkerman
Tinkerman
Tinkerman
Yep and a bunch of opportunity for failure!
Tinkerman
DNK
Reminds me.
Haven't had spaghetti in a while.
Geo Hahn
I stared at it awhile and compared it to a couple of photos of other center panels -- couldn't see anything amiss, but then couldn't see everything.
You can certainly test it before you offer it up to the final position in the dash... this should let you check everything and get at the backside a bit easier than once it is in place.
Really, with care & double checks it is quite likely that all will go right the first time.
Tinkerman
Tinkerman
Thanks Geo, that's what I kinda figured. I tend to over engineer everything, but then again what can I lose by being over careful?
Tinkerman
Rhodyspit75
As a long time Electrical Contractor I have decided that if I paid attention while I did it and checked it once it's time to throw the switch. The dash looks good by the way, but don't forget the keys!
Platinum
:lol:
Same thought here... It's gonna be a contest to clip that tie-wrap lyin' upside-down with yer feet higher than yer head and a "workspace" the size of a thimble. :devilgrin: :jester:
JimLaney Bench Testing starter Spridgets 8
K TR4/4A Generator bench testing..... Triumph 6
P Bench Testing a wiper motor???? Spridgets 3
M Healey Overdrive Bench Testing Austin Healey 2
T Bench testing a coil Austin Healey 3
Tinkerman Bench Testing Electrical Components Triumph 13
CraigLandrum Rebuilding and bench testing a fuel gauge? Triumph 9
vping Bench testing the Generator MG 15
A TR4/4A TR4A control box bench testing Triumph 4
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
bugedd Bench bleed tips Spridgets 14
TomMull Desmond Stephen bench vise Restoration & Tools 0
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
F 12Volt Bench Power Supply Austin Healey 4
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
steveg Calculating front bearing shims on the bench Austin Healey 8
mgedit Bench Bleeding Master and Slave Cylinders Triumph 5
Banjo bench-top mill Restoration & Tools 1
John_Mc Bench bleed slave cylinder? Triumph 4
T How bench test Pertronix unit Triumph 3
K TR2/3/3A TR3:What year did they switch to the rear bench... Triumph 9
Bruce Bowker Bench Vise Restoration & Tools 9
drooartz Soon this bench will be covered in greasy bits... Spridgets 4
TimK running wiper motor on the bench Austin Healey 4
Shealey can someone explain how to bench test wiper motors Spridgets 11
D alternator charges on bench but not in 95 XJ6 Jaguar 4
John Loftus bench test wiper motor Austin Healey 2
J Bench Press Restoration & Tools 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A Testing spark plug wires..... Triumph 11
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
MadMarx Wedge Testing on Airport Triumph 0
nevets Testing OD with Car on Jack Stands Austin Healey 9
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
FlyingCat Spitfire Smoke Testing Triumph 12
S Testing and Adjusting procedure for RB340 Austin Healey 4
C Testing heater core Austin Healey 9
doc50 Mash Metropolitan Generator testing Other British Cars 1
K TR2/3/3A Compression testing again... Triumph 4
steveg PCV Valves - testing Austin Healey 8
B General TR Testing the Waters Triumph 5
Griz Testing Vacuum Advance Austin Healey 5
D TR4/4A Testing the starter Triumph 4
K TR2/3/3A Wiper motor testing? Triumph 7
DornTRoriginal TR2/3/3A T4A Type OD Transmission Operation Testing Triumph 6
D Testing crankcase oil Austin Healey 4
Gordon_Dedrick Testing an A type overdrive Triumph 20
B Battery/generator issues - Testing generator Austin Healey 16
