CraigLandrum
In the process of restoring my central gauge panel, I was checking all the gauges and noticed that when I ohmed out the terminal on the fuel gauge, it was open. Took it apart and examined it. There are two electromagnetic coils to the right and left of where the needle goes and a flatter coil directly underneath the needle pivot mechanism. After carefully disassembling the needle area I discovered that the flat coil was toasted so I stripped off the old wiring and rewound it with the same gauge enamel magnet wire (it has 200 turns if anyone is interested), and made sure that the ends were properly touching the two terminals. Put everything back together and now I get continuity between the terminals and about 112 ohms between each terminal and the case (I believe this is measuring the ohms of each electromagnetic round needle deflector coil).
I want to bench test this but for obvious reasons don't want to just hook the two terminals up to a 12 volt battery since all that would do it turn my new gauge coil into a nice temporary light filament.
I have variable bench power supplies and any resistors that may be needed. Anyone out there ever bench test one of these puppies? I don't have the fuel tank handy (its being reworked) but did want to verify correct operation before installing my new panel.
I assume that the case is ground and one terminal is hot and one comes from the fuel level sender.
Suggestions welcome.
