Testing crankcase oil
DickN
Member
I am sure many of us have cars that don't get driven much,
but wonder if the oil that been in the engine for a couple
of years is still O.K.
I just received a testing device that will give you the
answers. Placing a few drops of oil in a small sensor tests
for acid, water and other impurities.It is called Lubricheck.
It seems to work as advertised. My Healey and Porsche were
o.k, the XK140 was marginal so its oil got changed.
( I have no financial interest in the product)
Dick
Keoke
You mean you live on top of Yarnell Hill ???---Keoke The Prescott:cowboy:
I ain't heard from Dick he must be -down on whiskey row !!:angel2:
DerekJ
Why not just change the oil? Every year at least or every 2000-3000 miles whichever is sooner. I change mine every 1000. Its a 10 minute job and oil is cheap relative to the cost of everything else on a Healey.
Keoke
WELL Derekj:iagree: But you see Dick lives on top of a mountain that is about one mile high and this being winter time it just might be so cold that the oil wont flow.:cheers:
DickN
Member
It does get cold here, but the real reason is economics. My three cars take a total of 30 qts., so that is $200+ dollars. My $40 tester has already saved me from buying 18 qts. that were not needed. $100+ dollars.
Dick
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A Testing spark plug wires..... Triumph 11
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
MadMarx Wedge Testing on Airport Triumph 0
nevets Testing OD with Car on Jack Stands Austin Healey 9
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
FlyingCat Spitfire Smoke Testing Triumph 12
S Testing and Adjusting procedure for RB340 Austin Healey 4
C Testing heater core Austin Healey 9
doc50 Mash Metropolitan Generator testing Other British Cars 1
JimLaney Bench Testing starter Spridgets 8
K TR2/3/3A Compression testing again... Triumph 4
steveg PCV Valves - testing Austin Healey 8
B General TR Testing the Waters Triumph 5
K TR4/4A Generator bench testing..... Triumph 6
Griz Testing Vacuum Advance Austin Healey 5
D TR4/4A Testing the starter Triumph 4
K TR2/3/3A Wiper motor testing? Triumph 7
DornTRoriginal TR2/3/3A T4A Type OD Transmission Operation Testing Triumph 6
P Bench Testing a wiper motor???? Spridgets 3
M Healey Overdrive Bench Testing Austin Healey 2
Gordon_Dedrick Testing an A type overdrive Triumph 20
B Battery/generator issues - Testing generator Austin Healey 16
jlaird Testing the Pic upload Spridgets 1
K TR2/3/3A Testing a TR3 lever shock? Triumph 7
I Fuel sender unit testing Triumph 2
T Bench testing a coil Austin Healey 3
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
KVH Final Testing of OD Triumph 2
Lynn Kirkpatrick Testing Fluids MG 3
S trouble shooting not working speedo or testing one Triumph 22
I Help testing motor Triumph 5
coj Testing send Austin Healey 2
Michael Oritt Dyno testing Racing 5
bigjones Testing Temp Sender Spridgets 5
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
MadRiver Testing Compression MG 1
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
R bBJ-7 testing fuel tank float Austin Healey 2
W Reminder about testing sending units Spridgets 8
R DEQ testing/passing & exhaust gas analyzer Spridgets 7
Tinkerman Bench Testing Electrical Components Triumph 13
wkilleffer Testing the fuel gauge MG 3
Tinkerman Testing Brake Lines? Triumph 1
B Lifter/ Rockwell testing results MG 14
R MGB Testing temp sending unit 1979 MGB MG 6
vette Testing w/pictures again Austin Healey 9
7 question after testing a J type overdrive Triumph 5
T Brake Drum Temps - Field Testing Triumph 10
Tinkerman Testing tranny/OD TR 3 A -PRESSURE TEST DONE!!!!! Triumph 28
