Final Testing of OD
KVH
Maybe the end for my OD rebuild experience. At least for now, I think I'm done.
I think it all checks out:
a) 375 lbs pressure
b) no leaks (yet)
c) wiring connected and tested, and solenoid kicks in
d) valve lift set to .025 (using adjusting lever)
e) plunger gap set to .150
f) runs with test motor
g) when OD kicks in, there is a click and the speed seems to become more steady, or perhaps to slow down (but that's likely because I'm spinning from the output flange)
h) when I hold the lever in OD, the flange will not spin CCW, but when released, it will
Am I ready to put this OD back in the car?
PS Randall, I copied your fitting for the Allen head crew to adjust the pinch bolt from under the car! Cool idea.
Also, Randall, you once warned of abusing the solenoid somehow during testing. Something to avoid doing. I forget the details?
Geo Hahn
Congrats, though you know what the real final test will be.
I suppose 'abuse' of the solenoid may be a test set-up that does not allow full deployment, thus not allowing the little switch to shut-off the pull-in coil?
Remind me why all this took place -- was it primarily to resolve leaks or was there an operation problem or failure?
TR3driver
Great Pumpkin - R.I.P
I don't recall giving the warning, but that would be it.
Sounds like it's all ready to go back in; though of course Geo is right about the final test.
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Bayless Ready for final block sanding Spridgets 5
R TR6 1973 Final drive issues Triumph 5
pbraun Bug i nearing final completion Spridgets 11
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
J Final painting detail questions Austin Healey 16
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
DornTRoriginal TR2/3/3A Final Check Items Restoration nearing completion Triumph 9
MadMarx TR4/4A [VIDEO] NĂĽrburgring RGB Seasons final race Triumph 12
dougie SOVREN Fall Final PRW Racing 2
B Final MARRS race of the season - free admission Racing 0
Pythias 1275 Transplant --- Final Report Spridgets 4
Jim_Gruber Bugsy's Final Goodbye Spridgets 4
glemon Final Rocker Shaft Question Triumph 5
F Final touches- a few detail questions for a BJ7 Austin Healey 11
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
drooartz Progress: garage space and the final list Spridgets 3
Tinkerman TR2/3/3A Final drive ratio for TR 3A Triumph 8
MadMarx [Video] RGB Seasons Final Nurburgring GP Track Racing 7
mikecyc72usa The final push Triumph 0
ncbugeye What tool to remove final drive filler plug? Spridgets 12
dougie HMSA Portland Historics 2009 Group # 7 Final Racing 4
zimmy 74 midget..............final price drop! Spridgets 7
ncbugeye Final drive on Bugeye Spridgets 17
SilentUnicorn The final straw Spridgets 26
reinaldo Stag Final stage in the restoration of my TR4A Triumph 23
Brosky Under windshield frame and final prep for paint Triumph 6
Brosky Final panel fitting & new mirrors Triumph 38
PATR8 Wedge TR8 repair mostly final tally Triumph 40
Brosky New Engine, the final chapter Triumph 3
Glen_B My final Ozark slide show Spridgets 1
regularman Well, just placed a final [hopefully] order Spridgets 8
JPSmit final question [tonight] - cleaning transmission Spridgets 5
bcliff Stuck Intake Valves.. The Final Chapter! MG 4
B Final Exhaust pics Spridgets 26
J Weber final adjustments-I hope Spridgets 2
T Final Timing Question [I hope] Triumph 10
M Rear axle [final drive] tools or information Restoration & Tools 5
billspohn Final Jamaican Pictures MG 22
regularman Can anyone tell me what the exact final ratio is.. Spridgets 15
jollyroger Sprite Parts Vortex final closing deals. Spridgets 0
A E-Type rear suspension/final drive continued.... Jaguar 4
David_K **Final Interior Combo Choice** Austin Healey 39
Simon TR4a Final cleaning before paint. Restoration & Tools 3
J MG plays its final act..[its sad and final] MG 3
Bruce Bowker eBay B - final price? MG 18
