Stuck Intake Valves.. The Final Chapter!
bcliff
The stuck intake valve saga has been continuing quietly for several weeks now. Here is how it went:
1. Got the Junkpile B running. Valves stuck after sitting overnight.
2. Removed head, cleaned up GOO in the head and re-installed. Ran good, Valves stuck the next day.
3. Put a different head on. Valves stuck again.
4. Soaked original head in tank overnight. Cleaned it all up, lapped valves. Re-installed it on the car. BEFORE I ever cranked it up, I changed the gas tank!!! Now it runs good, after sitting all night in subfreezing temperatures. The old tank has about 1/16 of an inch of GOO in the bottom. When I say GOO, this stuff looks like the thick, brown, sticky Permatex Gasket stuff.
As I was removing the valves from the head that had soaked overnight, Frankenstang (Junkpile Spitfire Guy) was there.
As I was removing one of the intake valves, he remarked that he had never seen any so stuck. I used a 3 pound hammer and punch to drive the valves out. There was sticky black stuff on the stems that glued them in place. When everything was cleaned, they slid perfectly.
So...Lesson learned. Check the "empty" gas tank that has been sitting for a few years. Junkpile B due to hit the road this week (fingers and toes crossed).
Bruce, Glad to have it all figured out)
tony barnhill
Great Pumpkin - R.I.P
WOO HOO....you apparently didn't follow https://www.theautoist.com/CHECKLIST.HTM where it advises to drop the tank & clean before ever trying to start the engine....hehehehe
Glad you solved the problem!
dklawson
The first LBC I worked on in high-school was a '64 B that had been parked for nearly a decade. We never thought to drop the tank. Based on your experience I'd say we were lucky. This particular B would run for a few miles and then the fuel system would plug up. Not having other means at my disposal, we washed the inside of the tank with paint strippers. It worked but I probably shortened my life because of that fuel tank.
I'm glad you got it sorted out Bruce.
Platinum
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Not to mention playing in mercury, rubbing it into dimes 'n quarters with yer fingers, solderin' up all those 'breadboard' experiments, attending grade school in a building with asbestos insulation on all the furnace ducting, ENJOYING th' smell of pumping gasoline, xylol and carbon tetrachloride as cleaning agents, sanding/painting cars, eating Reddi-Whip on apple pie... an endless list.
I may as well just go lie down inna back yard an' WAIT fer it. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
bcliff
bcliff
My first car experiences were on Model A Fords (when my peers were messing with 57 chevys and Camaros). At one point, my brother and I needed to replace a gas tank on one of our cars. The only extra we had contained a bird's nest. How do you get that out we wondered. My older but not wiser brother thought it would be a good idea to burn it out. Singed eyebrows, lots of running, you get the picture. I guess I am pretty lucky, or perhaps my guardian angel likes cars.
I did manage to learn many good life lessons at my brother's expense.
Bruce
bcliff Stuck Intake Valves...Unstuck! MG 3
bcliff Stuck intake valves, Why? Triumph 3
bcliff Stuck intake valves, Why? MG 8
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
