Stuck intake valves, Why?
bcliff
Junkpile B has been running good. I started it up Friday, it ran great. Tried to start it this afternoon, and it spins freely, like the spark plugs are out. I pulled the valve cover, and all four intake valves are stuck open. I have had a valve stick before, but not all four. I tried to pull them shut, but they won't budge. I figure the head is going to have to come off, but any ideas as to what is causing this will be appreciated. Possible cures without pulling the head would be good too. the engine sat for quite a few years without running, so maybe getting it out on the highway and "blowing the cobwebs out of it" is what it needs.
Thoughts??
Bruce
jlaird
I would suspect I would pull the head and take a look. Worse case off to a head rebuilder.
tony barnhill
Great Pumpkin - R.I.P
Have you whacked the valves with a big rubber mallet? & does it look like the system is oiling them?
TheSearcherMan
I had an MGB that had been sitting one time. The valves also stuck open. In my case, I was able to get them unstuck, but they stuck again. I did drive the car, it didn't help. I used all types of penetrating lubs, and the valves kept on sticking. You should have a complete head job at a machine shop if you want to do it right. Also, I would question the condition of the rest of the engine. I was unable to repair that MGB without removing the head. If you hammer the valves to try to free them up, be careful, because you may bend a valve, the pistons are down there you know. The problem is corrosion.
PAUL161
Their probably coated with gum or varnish, what ever you wish to call it and when heated up will turn to cement if its thick enough. Very common on antique cars that have set for many years. Pull the head, pull the valves and clean the whole mess up. It's not a hard job! It would also be a good time to have the head checked for cracks and valves reground, Afterward, do as Tony says and make sure their getting lubricated properly. JMHO. PJ
bcliff
bcliff
I'm thinking gunk is the problem too. The engine runs great and has good oil pressure. The donor car, a 74 GT is not a high mileage car.(Anyone need the body?). The valve cover has a layer of varnish inside. I think I read somewhere that this is common in in cars that have been run with paraffin based oils. The rockers are oiling well. New head gasket set is supposed to be here Wednesday. Looks like Tuesday will be disassemble and clean day. I'll get to have a look at the pistons and cylinder walls too. I don't expect any surprises, since the car was running when parked. I actually know the owner of the car and I know it is really true when he says that.
Bruce
bcliff
bcliff
On another note, this engine is a "get it running and drive it a while engine". It is out of a 74 (it is an 18V engine). The Junkpile B is a 69, and we have a proper 69 motor to rebuild properly, so it makes sense to put the money into the "69 engine.
Bruce
PAUL161
bcliff said:
the valve cover has a layer of varnish inside.
Bruce
Speaking of valve covers. The valve cover is the coldest part on an engine and deposits will collect inside there before anywhere else. It is the greatest quick indicator of how an engine was maintained by it's previous owner. I always pull the valve cover or covers before buying an engine and look inside it. Sludge inside, they never changed the oil and that means crud in the oil galleys, bearings and everywhere imaginable. Clean valve cover, the PO took reasonable care of the engine and it has a better chance of being ok. It's just a rule of the thumb I use and it doesn't always work, but it helps.
bcliff Stuck Intake Valves.. The Final Chapter! MG 4
bcliff Stuck Intake Valves...Unstuck! MG 3
bcliff Stuck intake valves, Why? Triumph 3
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
