Final cleaning before paint.
Simon TR4a
Sorry if this has been discussed, I couldn't find it in the files.
What is best to remove traces of oil or silicone, methyl hydrate, mineral spirits (what is that?), Varsol, lacquer thinners?
Simon, ( /ubbthreads/images/graemlins/confused.gifconfused.)
Darwin
Bronze
whatever paint system you are going to be using on the car should have its own prep solution. It may be more expensive that lacquer thinners and the like but it is designed to work with your paint. better to be safe than sorry with the cost of some of the modern paints.
Bugeye58
Simon, I use "Wax and Grease Remover", which is a dedicated paint prep solution. I think it is essentially naptha, with a few 'zenes and 'anes added to it. Any good paint supplier should have it available.
And, don't forget the "tack cloth" prior to paint!
Jeff
Banjo
A common one on the market is Prep-sol (or DX330). It's by PPG I believe. Take Bugeye58s advice and ask your Auto paint store what is reccomended to use with the paint system you are going to use.
If you are painting it yourself in your garage(or some other home made paint booth) Be sure to take as much care prepping the "booth" as you do your car. Clean, clean,clean the area, and make sure any oil or other fluids are FAR away.( espically anything with silicone like WD40). Any possible contaminants can ruin a perfectly prepped paint job.
Good luck.
JPSmit final question [tonight] - cleaning transmission Spridgets 5
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Bayless Ready for final block sanding Spridgets 5
R TR6 1973 Final drive issues Triumph 5
pbraun Bug i nearing final completion Spridgets 11
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
J Final painting detail questions Austin Healey 16
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
DornTRoriginal TR2/3/3A Final Check Items Restoration nearing completion Triumph 9
MadMarx TR4/4A [VIDEO] NĂĽrburgring RGB Seasons final race Triumph 12
dougie SOVREN Fall Final PRW Racing 2
B Final MARRS race of the season - free admission Racing 0
Pythias 1275 Transplant --- Final Report Spridgets 4
Jim_Gruber Bugsy's Final Goodbye Spridgets 4
KVH Final Testing of OD Triumph 2
glemon Final Rocker Shaft Question Triumph 5
F Final touches- a few detail questions for a BJ7 Austin Healey 11
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
drooartz Progress: garage space and the final list Spridgets 3
Tinkerman TR2/3/3A Final drive ratio for TR 3A Triumph 8
MadMarx [Video] RGB Seasons Final Nurburgring GP Track Racing 7
mikecyc72usa The final push Triumph 0
ncbugeye What tool to remove final drive filler plug? Spridgets 12
dougie HMSA Portland Historics 2009 Group # 7 Final Racing 4
zimmy 74 midget..............final price drop! Spridgets 7
ncbugeye Final drive on Bugeye Spridgets 17
SilentUnicorn The final straw Spridgets 26
reinaldo Stag Final stage in the restoration of my TR4A Triumph 23
Brosky Under windshield frame and final prep for paint Triumph 6
Brosky Final panel fitting & new mirrors Triumph 38
PATR8 Wedge TR8 repair mostly final tally Triumph 40
Brosky New Engine, the final chapter Triumph 3
Glen_B My final Ozark slide show Spridgets 1
regularman Well, just placed a final [hopefully] order Spridgets 8
bcliff Stuck Intake Valves.. The Final Chapter! MG 4
B Final Exhaust pics Spridgets 26
J Weber final adjustments-I hope Spridgets 2
T Final Timing Question [I hope] Triumph 10
M Rear axle [final drive] tools or information Restoration & Tools 5
billspohn Final Jamaican Pictures MG 22
regularman Can anyone tell me what the exact final ratio is.. Spridgets 15
jollyroger Sprite Parts Vortex final closing deals. Spridgets 0
A E-Type rear suspension/final drive continued.... Jaguar 4
David_K **Final Interior Combo Choice** Austin Healey 39
J MG plays its final act..[its sad and final] MG 3
Bruce Bowker eBay B - final price? MG 18
