Brake Drum Temps - Field Testing
T
Tinster
It was a beautiful day here on the island and since
I have just adjusted my rear brakes I thought some
amateur field testing might be fun.
Data Points:
Ambient air temp 78*F
TRF rear brake pads 1800 miles use
TRF pads adjusted less than 100 miles ago.
TRF rear brake hoses 1800 miles use
TRF brake Master cylinder 2500 miles use
TRF rear brake wheel cylinders 2500 miles use
Brake fluid 2500 miles use
Brake drums painted with 1300*F ceramic rattlecan
Ambient brake drum temp in garage 78*F
Raytheon infrared temp gun - 18 months use
Expressway- tapped the brakes a few times to warm them up.
1. 70 MPH w/ panic brake to shoulder. Wheels NOT locked up.
Brake drum at 108*F
2. Continued to 60 mph for a few minutes; panic brake to shoulder, wheels NOT locked up. Brake drum at 99*F.
3. Continued to 60 mph for a few minutes; panic brake to shoulder, wheels NOT locked up. Brake drum at 97*F.
4. Continued to 75 mph for a minute; panic brake to shoulder, wheels partially locked up. Brake drum at 118*F.
5. Pulled into the Biker bar for a tall, cold one.
Normal braking from 50 mph to parking lot. Brake drum at 97*F
I also noticed the brake drum cools down quickly was well.
The system appears to be designed to stop and shed heat as well.
Amateur data - take it for what it's worth.
dale
roofman
I think you may be taking this too seriously Dale. Just make sure you have a complete brake system parts supply in the trunk, as well as the tools to replace them and you will be fine.
Platinum
Gad... if it stops without pulling to one side or the other and doesn't SMOKE after ONE "panic" stop the brakes are fine!!
..and rear brakes on that lump have SHOES not ~pads~ for stopin' it. PUSH friction rather than clamps. Go get that book and read summmore, Dale. :laugh:
T
Tinster
Not my thread Doc!!
Someone recently asked about rear brake drum temps
during hard breaking. I supplied the data.
My car stops on cue and straight, that's all I care about.
the test data was for others who asked for it.
d
Platinum
Ahhh... my bad. What I get for not bein' here more.
Your data is "textbook" normal, BTW.
prb51
As per the other thread...rattle can spray the drums with off the shelf high temp in the color of your choice, they rarely get that hot unless 1. You are racing 2. You drive with the emergency brake on (alot) 3. You live at the top of Pikes Peak....
DNK
I use kids water color. easier to change the color that way.
Platinum
But it gets flakey. :jester:
kodanja
This entire thread is Flakey
ichthos
The scientific method in action. Thanks, Tinster. I was the one who asked for the brake drum temps. I am actually working on a Bugeye and a TR6 at the moment. I am going to try high temp engine paint on the TR6 drums and powder coat on the front and rear brake drums on the Bug to see how they hold up. I did contact Eastwood technical support that said the standard powdercoat paint will work fine. I'll let you know how they do after I do some driving.
glemon
I have used plain old Rust Oleum paint of a number of brake drums, no issues with heat and paint even after many 1000 miles of spirited driving. No racing though.
D Rear Brake Drum Nuts Austin Healey 15
Upland 69 Sprite drum brake adjuster Spridgets 7
D brake drum question Austin Healey 5
I Bugeye drum to disk brake conversion Spridgets 23
M Brake Drum Help - 60 Sprite Spridgets 88
W Bugeye With Squealing Drum Brake Spridgets 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
warwick-steve Brake drum check and lubrication Austin Healey 9
NutmegCT T-Series TD brake drum removal MG 0
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets stuck rear brake drum Austin Healey 18
R BT7 Brake Drum Color Austin Healey 7
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
A rear brake drum too tight after rebuild Austin Healey 3
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
K TR2/3/3A Rear brake drum won't go on? Triumph 12
Sarastro T-Series Brake Drum Relining MG 0
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
P Bugeye front drum brake picture Spridgets 7
glemon General TR Rear Drum Brake Adjustment Triumph 2
W Brake Drum Tolerance ? Austin Healey 2
J TR2/3/3A Rear drum brake noise, Why?? Triumph 4
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
R BJ8 Brake Drum Removal Austin Healey 6
nevets Questions about rear brake drum removal Austin Healey 24
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
BillD Bug Eye front drum brake question Spridgets 12
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
K TR2/3/3A TR3A New Brake pads binding to New drum? Triumph 4
J Drum brake dragging. Spridgets 11
tri_carb_healey brake drum work, proper jack points Austin Healey 12
Parker TR2/3/3A TR3A Brake drum removal: RUST! [Arghhhhhh] Triumph 23
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
B Hot rear brake drum Austin Healey 9
G Brake drum dress up Triumph 13
K brake drum paint Austin Healey 16
tri_carb_healey rear drum brake problem Austin Healey 6
prb51 Brake drum Temp Triumph 6
Flash_Gumby ar brake drum lockup Austin Healey 4
M froze brake drum? Triumph 8
NutmegCT drum brake symptom Other Cars 59
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Geo Hahn Brake Drum Concentricity Triumph 15
SCguy Wedge TR8 rear brake drum removal Triumph 28
bigjones Brake drum leaking differential oil Spridgets 29
T Some info on front Brake Drum Securing Screws Spridgets 5
I Bugeye front brake drum temp? Spridgets 2
