B
BUNDYRUM
I removed the speedo and tach, when I took out the glass there is a steel ring it sits into. What is the color supposed to be on this ring. At present the black paint is flaking off so I am unsure if it should be matt or gloss?.
Also, who sells the correct shape rubber ring that sits on the metal ring and supports the glass?. One of the gauges had a rubber ring on both sides of the glass. The inside ring was smaller in crossection than the outside ring. My parts manual only shows 1 ring in each gauge.
I have a 1960 BN7.
Regards
bundyrum.
I have a 1960 BN7.
Regards
bundyrum.
