True, but not on the same fuse.
Also, the ignition warning light is not grounded through the panel. (It actually grounds through the generator armature, which is why it goes out when the generator is working.)
I think you must have multiple problems, that just happened to show up at the same time. Pick one and troubleshoot it; then recheck the others.
But, while you have the panel out, I would definitely clean any stray paint off of the ground tie point on the back. Also add a ground wire from there to the fuel gauge mounting post (if you don't have one already).
