instrument led lamps
BJ8TONY
Hello all.
Some time ago I remember reading about LED replacement lamps for the dash instruments.
I tried to find the link but no luck.
Can someone please reply with a link to the site that carried them.
Thanks
BabaKahawa
BJ8TONY
Search the BC forum using this number #407760.
I saved the article on my computer, but I do not think it will fit in this post. I can always email it to you if you can not find it. i did the LED conversion. It does work well, but you do get a glare for the instrument glass at night.
The post came from AUSMHLY "How to: Brighter gauge face with LED’s" It was posted 02/09/08
robert_ellison
I am confused how to actually install these bulbs, Also don't know where to find the "AUSMHLY "How to: Brighter gauge face with LED’s" article.
Johnny
Duane_Rhynard said:
Tony,
https://www.autolumination.com/
Good luck,
Duane
58 BN6
Duane, did you use the "74" bulbs? Did the 3/8inch bulb fit in the holders for the Healey? Or did you have to buy the twist lock bulb bases instead?
BabaKahawa
Johnny;
I installed the LED lights in my BN6.
I used a T10, super white color E10 screw Superstar w/ Heatsink from "www.autolumination.com.
I unscrewed the old bulbs and installed these. Installed quick, it took more time to get into the footwell then to install the Led bulbs.
Thanks Roger for the LED article,
I have not drilled for the extra bulbs in the instrument gauges yet, that will be my winter project.
Johnny
Thanks Roger for the Link to the thread, saves time.
I've tried replacing the older bulbs with newer one's. Now I have a lot of light but lots of flash back from the gauge glass, the fuel gauge in particular. The fuel gauge has a blue plastic strip that diffuses the bulb light mounted above it, in my car that strip is missing. Currently, I can't even read the gauge at night. I suppose I have to remove the bulb altogether and replace with a LED. I don't like drilling into the fuel gauge for mounting though.
AUSMHLY
Hi Johnny,
The fuel gauge in my BJ8 does not have a blue plastic strip. I'm not sure what your referencing.
There are two places that illuminate the gauge face. The light shines in through the opening where the needle is and there is a small round opening under the half way mark on the bottom of the gauge that light shines up through.
There is no place to drill a hole for another bulb.
The 2.2 watt filament bulb can be replaced with a 4 watt filament or the one watt led, as referenced in my article.
Both will work great.
Cheers,
Roger
Johnny
Sorry Roger, I should've been more specific. My BJ7 has the gold faced gauges where both the safety gauge and the fuel gauge have the bulbholder above the gauge. Surrounding each are openings to allow light onto the gauge. Also, above the openings are blue tinted strips of plastic that allow light through to illuminate the gauge face. At least that's how it's supposed to work.
B
BUNDYRUM
Hello Johnny,
yes that's how it's supposed to work with the fuel and water temp/oil pressure gauges.
When I fitted LED's to my BN7 I found that with these 2 gauges there was light only coming from one side of the gauge.
I made another bulb holder and mounted it on the opposite side to the original one so now I have 2 LED's for each of those gauges with plenty of light.
You don't need to drill holes in the back of these 2 gauges, just the Speedo and Tach.
Best regards,
bundyrum.
AUSMHLY
BUNDYRUM said:
Hello Johnny,
Best regards,
bundyrum.
Hi Bundyrum,
Could you post some photos showing how you mounted the bulb holders you made? I'd be interested to see that, as I'm sure others would too.
Cheers,
Roger
bighealeysource LED Instrument Lights Austin Healey 12
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
edkap2002 TR6 Brighter instrument lights? Triumph 0
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
LAW75 Instrument Panel Lights Austin Healey 9
Crankshaft TR2/3/3A Instrument troubleshoot Triumph 7
steveg Improved Instrument Lighting Austin Healey 2
Crankshaft TR2/3/3A Instrument panel cleanup Triumph 4
Gerald_Gordon TR4/4A TR4 instrument panel Triumph 7
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
S Instrument Panel Lights Spridgets 6
R TR4/4A Question about cleaning instrument faces Triumph 8
MGTF1250Dave T-Series TF Dash Instrument Panel Studs Size MG 2
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
CJD General TR Instrument Faces Triumph 111
Jim_Gruber Instrument Bezels for BE Instruments Spridgets 4
Gerry M TR6 Instrument panel light bulbs Triumph 1
L Instrument O rings and switch plate mounting Austin Healey 4
Nelson Instrument bulb replacements Spridgets 14
T current instrument rebuilding info from Nissonger Austin Healey 3
M TR4/4A tr4a instrument knob removal? Triumph 9
T XKE Series 2 Instrument Panel Jaguar 2
M Instrument lights, etc. Triumph 8
AH100M 100/4 Instrument panel silver paint Austin Healey 5
Tinkerman TR2/3/3A TR3A Dash and Instrument Cluster Installation Triumph 11
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
Tinkerman Instrument Cluster Assembled, YEA ! Triumph 22
Tinkerman TR2/3/3A Instrument Cluster TR 3A Triumph 14
J TR2/3/3A TR3A instrument restoration Triumph 11
Nelson New instrument lamps Spridgets 10
HerronScott TR4/4A Smith's Instrument List for TR2-4A? Triumph 1
Tinkerman TR2/3/3A Instrument Panel TR3, Question about back. Triumph 29
T MGB MGB Instrument Lighting MG 7
prb51 TR2/3/3A TR3 instrument lights Triumph 4
J Removing Healy wood instrument panel BJ7 Austin Healey 3
HEALEYJAG BN1-instrument light wiring harness Austin Healey 0
B What is the color inside the instrument. Austin Healey 2
10musketeer Cleaning Instrument Faces Restoration & Tools 1
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
jjbunn Instrument Dial Rims Triumph 12
Tinkerman TR2/3/3A TR3 Instrument Glass Triumph 5
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
PAUL161 Instrument Bulbs MG 12
S Spitfire 74 Spitfire instrument panel, Walnut or Teak? Triumph 5
M 87 XJ6 Instrument Problem Jaguar 3
2wrench TR6 Instrument & other bulbs for TR6 Triumph 5
