I have refinished the glove box but now the instrument cluster looks drab so I thought it would be easy to pull the instrument cluster off the same way. Doesn't seem like the same job.
I am only trying to loosen the entire panel first and then was going to take the instruments out one by one, but while the glove box had two bolt connections (one recessed in the door hinge area and another above the center of the glove box) it appear the instrument panel has those connections and a couple of others I can't see.
Can anyone take me stepwise through the right steps to remove the instrument panel...perhaps I have to disconnect all the gauges to see what I need to do...I was just hoping to pull the whole panel done and start from there.
thanks in advance
Jersey
thanks in advance
Jersey
