New Clutch Master Cylinder
PATR8
We had a 4 day pass this past weekend and it ends today so today I had to do some local running (Bank, dentist, lawyer)so I took my 8 out for a jaunt. I had ordered a new master cylinder from Woody last week so I figured it would be here today,so before I left I could see my old one was down a little. On my way home I shifted and felt more play in the clutch and by the time I got home it had given up the ghost. I did a little lawn work and it is oppressive outside. I came in a and did a little work and decided it was time to swap the Master cylinder.
I last 5 minutes before I pulled her into the garage. Only took about 20 minutes but will be nice not having to top off the clutch each time I get gas.
Side note, as I was leaving the dentist a lady pulled in beside me and as I backed out she pointed out there were a few drips of oil on the ground (I assume she is just very attentive because it truly was a few spots). I laughed and said all British cars leak. I explained you just have to keep an eye on the oild level. She then said, well with it losing that much oil, you should never have to change it as it will always be new. With a smug look, she walked off.
I think she may have a point
PATR8
PATR8
funny you ask, yes I did. Not sure What made me think of doing it
tr8todd
Did you try to rebuild the one you have? Rebuild kits are cheap and it only takes a few minutes to do. Once the bore gets pitted, you might as well buy a new unit. Had one resleeved with brass a couple of years ago, but that cost twice as much as buying a new one. I like to use the dot 5 silicone on the clutch hydraulics. Doesn't hurt the paint when it spills.
PATR8
PATR8
I with the silicone just because I read about it. Sadly, I had a 2 year old master cylinder sitting in my garage from the FHC I had and I forgot about it. So I have a spare and one I will look at tonight and see if it is worth savings
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
J clutch master cylinder bore diameter? Triumph 1
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
