rlandrum
We're in the middle of our frame off, and I'm about to order a blaster and blasting material to strip the body. The body is mostly metal, with two fiberglass rear panels. There's very little to rust on the car.
I've decided to purchase a soda blaster, although I won't do soda blasting for this frame off. Eastwood sells a $250 soda blaster that will do regular media and soda (which requires a special valve).
I picked, for paint removal only, a poly bead from Eastwood. It's a plastic, Poly 20/30 grit, and they say it's best for removing paint while leaving the sheet metal intact. To remove the few spots of rust, I've picked a 70 Grit Aluminum Oxide.
I've estimated that at 25 CFM, I can blast about 8 square feet per hour with the poly bead, and that the car is probably somewhere in the 60-80 square foot range. I'll blast through about 75 lbs of poly bead per hour. I plan to purchase 100 lbs of bead, and recycle it until the job is done.
To those that have done this in the past: Does this seem like a logical plan? Are these the right materials to use?
