Hi;
New member here, Bob and I'm jumping in with both feet on a 1960 Bugeye Sprite. I originally posted this over in the Big Healey Forum and it was nicely pointed out that I might get better info her with the other little guys. The car currently painted yellow, kind did it in my garage type job and I'm planning on doing a bare metal job, then rebuilding all the systems when it's done. I did get a certificate of authenticity from BMHT which indicates it is a matching numbers car-only it left the factory with white paint. I found a guy on the other side of Philly that does dustless blasting and am wondering if anyone has done this before. According to the owner of the shop, it uses a slurry of water, rust inhibitor, fine crushed glass and low pressure high volume air to strip all paint. Has anyone done this before? They actually had a Bugeye in their shop that was blasted the day before and it looked pretty good. Apparently it strips off bondo and paint and they found an issue with the rockers which will need replacing. I think my car is pretty solid but I guess you never know.Thoughts or comments?
Bob
Bob
