The type media depends on what you are blasting, if it's rough , rusty parts, then sand or aluminum oxide works well, if more delicate work is needed for like engine parts, which is what I'm mostly blasting, then glass bead, I use a fine glass bead in my big Skatblast cabinet, then in a second blast cabinet I use plastic media for carb parts.
I think one othe worst mistakes you can make with a blast cabinet is thinking is some sort of magic wand, some serious clean up needs to take place before the part ever makes it way into the cabinet, heavy rust scale, thick coats of paint all need to be removed from a part before it is blasted, otherwise you will just clog up your cabinet. Another consumable on your bead blaster is the tips, most cabinets come with white ceramic tips, which wear extremely quick, and if your tip has worn until it has huge ID in it now, compared to when it was new, then the overall pressure and effectivness of the blaster is compromised. Now I used my bead cabinets alot, everyday, so I go thru a few hundred pounds of glass bead every year, and when I used ceramic tips, I went thru them like crazy, I looked at what TP Tools had to offer in tips and they offered a carbide tip, it was expensive when compared to the replacment packs of ceramic tips, alot higher, like $40 buck for the single carbide tip, but it was the best decision I ever made, blaster-wise, because I'm into my third year with the same tip, in the same amount of time, I would have went thru several dozens of ceramic tips , so in the long run the carbide tip was cheaper to use.
